Home » Archived » WTP - PAVE » Comments on Project Proposal
Comments on Project Proposal [message #468613] Mon, 18 May 2009 15:57 Go to next message
First I'd like to say that automation of commands and easy composition of
high-level actions into even more higher-level actions is a functional
area that is sorely missing from Eclipse.
Having said that, I am concerned about the way this project is positioned
and the implementation choices (WTP Data Model Wizard Framework) that are
described. In order for a facility such as this to be truly effective, it
should not be tied to WTP. While your initial uses for the framework are
WTP-based, placing this technology into WTP and making it have WTP
dependencies would artificially constrain the scope of the potential
community and permanently limit its reach. Then if in the future, command
scripting is added to Eclipse Platform, this framework and all users of it
instantly become obsolete.
I would make two suggestions:
1. Re-evaluate your dependency on WTP-specific technologies (such as the
data model wizard framework) and see whether you can achieve your goals
without it.
2. Move the project proposal from WTP Incubator to Technology project or
even the Platform Incubator. Co-ordinate your activities with the platform
team.
The relationship to the Eclipse Command Framework needs to be rationalized
as the commands already represent encapsulated high-level actions. In
effect, you are proposing a framework that would compose even higher-level
commands out of other commands. I would recommend that you solicit
feedback from the platform team. Also consider that in the future, this
technology might need to expand into scripting and recording.
Re: Comments on Project Proposal [message #468615 is a reply to message #468613] Wed, 20 May 2009 03:18 Go to previous messageGo to next message
Hi Konstantin,
First we absolutely agree that the framework should in the end go in the
platform. But we also think that the WTP Data Model framework should go
there. The PAVE framework depends only on the data model framework from
WTP, so we intend to create a separate downloadable with DMF as a first
step.
And if the PAVE framework gets enough attention we can try to push it in
the platform.
I will try to explain our vision for the framework, thus I think answering
most of your questions.
The idea behind the framework is actually easy sequencing of operations
existing and non-existing ones. We want to build a data model with all of
the data needed for all operations and then execute them in a single pass.
Also UI should be reusable, one and the same page could be used for
gathering data for creating a java class for instance and in the same time
to be reused in one of the steps of a certain pattern. Reusability is one
of our top priorities.
We want these operations to be able to be executed in headless mode, so
there can be multiple actions for executing one and the same pattern (drag
and drop, within other frameworks, separate actions), since the framework
itself will be invisible for the regular user. The developer should see
only the patterns that are contributed.
Scripting of operations is a think worth thinking of and we can include it
in future versions.
I hope I have answered your questions,
Dimitar
Re: Comments on Project Proposal [message #468617 is a reply to message #468615] Wed, 20 May 2009 03:29 Go to previous messageGo to next message
Just forgot to add that most of these features already exist in DMF plus
more really useful features for ui synchronization that make creating of
wizards really easy, the model is completely separated from the UI that is
something that is missing in platform as well. And having in mind there 2
things can greatly benefit from each other.
Re: Comments on Project Proposal [message #468619 is a reply to message #468617] Thu, 21 May 2009 18:11 Go to previous messageGo to next message
As someone who has learned this the hard way (faceted project framework),
starting technology out in WTP with intentions of moving it lower in the
stack at a later date sounds good in theory, but is exceptionally costly
approach in practice.
It is significantly cheaper to start without WTP dependencies (including
dependencies on WTP namespaces (org.eclipse.jst and org.eclipse.wst)) than
it is to start out this way and then try to pull out, while maintaining
backwards compatibility for WTP. You also have to consider how you plan to
build a community around this. Again speaking from experience, it doesn't
matter how good your technology is, you will not get adoption and grow
your community beyond the sphere of adopters who build on top of WTP
already while this technology is part of WTP. Providing a separate
download will not change this situation in a meaningful way as perception
of positioning, influence and tie-ins factor in significantly in adoption
decisions. Further, you are always in danger of someone undermining all of
your work by building something similar in function lower in the stack (or
at least outside of confines of any one particular vertical tooling
project).
I would recommend that you guys at least discuss this with the Platform
team. I appreciate that you already have a code base built on the data
model framework, but if that's the only reason that you can't start out
outside of WTP then you are selling your technology short. In the long
run, it would be better for you to invest the time to remove your
dependency on the data model framework so that you can start immediately
positioned to maximize your potential community.
- Konstantin
Re: Comments on Project Proposal [message #468621 is a reply to message #468619] Fri, 22 May 2009 22:43 Go to previous messageGo to next message
Hi Dimitar,
Not sure where in the Platform this may end up but how about a call before
the creation review to get to know each other, and what you are trying to
accomplish? If the proposed technology is already implemented in a product,
you could even give a demo of it. Just set up a poll on doodle.ch with
suggested times...
Boris
"Konstantin Komissarchik" <konstantin.komissarchik@oracle.com> wrote in
message news:4e80f83e0e86aee8b6da48456251f61e$1@www.eclipse.org...
> project).
> - Konstantin
Re: Comments on Project Proposal [message #468623 is a reply to message #468621] Mon, 25 May 2009 08:17 Go to previous messageGo to next message
Hi Boris,
Dimitar is on vacation this week. So, let's schedule this call for next.
Please, give your vote for date & time here:
http://www.doodle.com/b58v7qm8i62zfmvw
We can use the SAP's PGiConnect infrastructure for the live demo.
Greetings,
Kaloyan
Re: Comments on Project Proposal [message #468627 is a reply to message #468619] Mon, 25 May 2009 12:23 Go to previous messageGo to next message
Hi Konstantin,
I agree that the right place of the new project is in the platform. All
your points with regards to positioning and adoption are valid. I just
have some concerns with regards to removing dependencies from Data Model
Wizard framework. Doing so we’ll have to build similar functionality in
the platform which means redundancy and all the consequences it will
bring.
Regards, Rado
Re: Comments on Project Proposal [message #468629 is a reply to message #468623] Wed, 27 May 2009 10:32 Go to previous messageGo to next message
Konstantin, could you mark your availability in the doodle poll.
I would like to fix the time for the call by tomorrow.
Greetings, Kaloyan
Kaloyan Raev wrote:
> Hi Boris,
> Greetings,
> Kaloyan
Re: Comments on Project Proposal [message #468630 is a reply to message #468629] Thu, 28 May 2009 14:20 Go to previous messageGo to next message
Well, looking at the doodle poll the day will be June 4th, Thursday. Our
preferred time is 1500 UTC.
I will send update the newsgroups and will send mails later with the
access info about the call.
Greetings,
Kaloyan
Re: Comments on Project Proposal [message #468632 is a reply to message #468630] Mon, 01 June 2009 08:48 Go to previous messageGo to next message
The demo will be held on June 4th, 1500 UTC
I will send call details shortly.
Re: Comments on Project Proposal [message #468635 is a reply to message #468632] Mon, 08 June 2009 09:29 Go to previous message
Here is the recording from last week:
https://sap.emea.pgiconnect.com/p65247632/
Re: Comments on Project Proposal [message #560602 is a reply to message #468613] Wed, 20 May 2009 03:18 Go to previous message
Hi Konstantin,
step.
the platform.
in future versions.
Dimitar
Re: Comments on Project Proposal [message #560608 is a reply to message #468615] Wed, 20 May 2009 03:29 Go to previous message
Re: Comments on Project Proposal [message #560616 is a reply to message #468617] Thu, 21 May 2009 18:11 Go to previous message
project).
- Konstantin
Re: Comments on Project Proposal [message #560623 is a reply to message #468619] Fri, 22 May 2009 22:43 Go to previous message
Hi Dimitar,
suggested times...
Boris
> project).
> - Konstantin
Re: Comments on Project Proposal [message #560631 is a reply to message #468621] Mon, 25 May 2009 08:17 Go to previous message
Hi Boris,
Greetings,
Kaloyan
Re: Comments on Project Proposal [message #560648 is a reply to message #468619] Mon, 25 May 2009 12:23 Go to previous message
Hi Konstantin,
bring.
Regards, Rado
Re: Comments on Project Proposal [message #560656 is a reply to message #468623] Wed, 27 May 2009 10:32 Go to previous message
Greetings, Kaloyan
Kaloyan Raev wrote:
> Hi Boris,
> Greetings,
> Kaloyan
Re: Comments on Project Proposal [message #560661 is a reply to message #468629] Thu, 28 May 2009 14:20 Go to previous message
Greetings,
Kaloyan
Re: Comments on Project Proposal [message #560670 is a reply to message #468630] Mon, 01 June 2009 08:48 Go to previous message
Re: Comments on Project Proposal [message #560686 is a reply to message #468632] Mon, 08 June 2009 09:29 Go to previous message
Previous Topic:Pave demo
Next Topic:A glance at Pave
Current Time: Sun Jul 20 16:39:35 EDT 2025
Powered by FUDForum. Page generated in 0.10608 seconds
