Home » Archived » BIRT » Can't add more than one x/y series to scatterplot
Can't add more than one x/y series to scatterplot [message #369046] Wed, 22 July 2009 13:49 Go to next message
The following code works fine when called once; but if called more than
once the chart blanks out. Any idea what I am doing wrong?
public void addData(String label, ColorDefinition color, ChartWithAxes
chart, NumberDataSet xv, NumberDataSet yv) {
Axis xa = chart.getPrimaryBaseAxes()[0];
Axis ya = chart.getPrimaryOrthogonalAxis(xa);
Series series = SeriesImpl.create();
series.setDataSet(xv);
SeriesDefinition xd = SeriesDefinitionImpl.create();
xa.getSeriesDefinitions().add(xd);
xd.getSeries().add(series);
ScatterSeries ss = (ScatterSeries) ScatterSeriesImpl.create();
ss.setSeriesIdentifier(label);
ss.setDataSet(yv);
SeriesDefinition yd = SeriesDefinitionImpl.create();
ya.getSeriesDefinitions().add(yd);
yd.getSeriesPalette().update(color);
yd.getSeries().add(ss);
Re: Can't add more than one x/y series to scatterplot [message #369049 is a reply to message #369046] Wed, 22 July 2009 21:11 Go to previous messageGo to next message
Just discovered that I can add multiple data sets -- provided they all
have the same size! What's causing this constraint?
Also, I was wondering if there was a way to get error messages out of
BIRT, rather than just blank charts whenever there is an issue?
Re: Can't add more than one x/y series to scatterplot [message #369050 is a reply to message #369049] Wed, 22 July 2009 21:33 Go to previous messageGo to next message
My bad, was swallowing the exceptions:
org.eclipse.birt.chart.exception.ChartException: Mismatch (96!=192) in
dataset count found in stacked runtime series
at org.eclipse.birt.chart.factory.Generator.build(Generator.jav a:998)
So BIRT really can't draw more than one series in a scatterplot unless all
series have the same number of points?!
Re: Can't add more than one x/y series to scatterplot [message #369064 is a reply to message #369050] Thu, 23 July 2009 14:57 Go to previous messageGo to next message
Testing if padding the NumberDataSets with Double.NaN is a workaround...
Noticed that if more than one x/y series are added, all but the first are
misplaced along the x axis; what's the correct way to add more than one
x/y series?
Re: Can't add more than one x/y series to scatterplot [message #369131 is a reply to message #369064] Tue, 28 July 2009 14:57 Go to previous messageGo to next message
Seems to work!
> x/y series?
Looks like I'm the first to try to use more than one x/y series in a BIRT
scatter plot? :-(
Re: Can't add more than one x/y series to scatterplot [message #369147 is a reply to message #369131] Tue, 28 July 2009 17:20 Go to previous messageGo to next message
Originally posted by: jasonweathersby.windstream.net
Eric,
Can you log a bug for this? Also all series do have to have the same
number of points, but you should be able to pad datasets in the after
dataset filled script to meet this goal.
Jason
Eric Jain wrote:
> Seems to work!
>> are misplaced along the x axis; what's the correct way to add more
>> than one x/y series?
> BIRT scatter plot? :-(
Re: Can't add more than one x/y series to scatterplot [message #468261 is a reply to message #369147] Tue, 04 August 2009 14:20 Go to previous messageGo to next message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=285620
Re: Can't add more than one x/y series to scatterplot [message #479673 is a reply to message #468261] Tue, 11 August 2009 18:16 Go to previous messageGo to next message
For the record:
Figured out that the proper way to have multiple x/y series in a scatter
chart (and other types of charts) is to create a single x/y series and
call setSorting + setQuery on the y SeriesDefinition to separate the data
points into distinct groups. This approach is cleaner, and avoids the
multiple-x/y-series flakiness.
Re: Can't add more than one x/y series to scatterplot [message #829654 is a reply to message #479673] Mon, 26 March 2012 11:50 Go to previous messageGo to next message
Hi Eric,
I know this was some time ago but I just found this on a search of the
newsgroup as this is exactly what I am attempting. Do you a have an
example of the solution you are able to share?
Thanks for your help,
Nigel
On 11/08/2009 23:16, Eric Jain wrote:
> For the record:
> data points into distinct groups. This approach is cleaner, and avoids
> the multiple-x/y-series flakiness.
Re: Can't add more than one x/y series to scatterplot [message #830768 is a reply to message #829654] Tue, 27 March 2012 23:14 Go to previous messageGo to next message
Nigel,
I do not think he did it with more than one data set. I think he just
grouped his data.
Jason
On 3/26/2012 11:51 AM, Nigel Daniels wrote:
> Hi Eric,
> Nigel
>> For the record:
Re: Can't add more than one x/y series to scatterplot [message #832560 is a reply to message #830768] Fri, 30 March 2012 05:27 Go to previous message
Hi Jason,
Thanks for getting back to me. Is what I am asking possible using Birt?
I'm trying to replicate something I have done in Excel so far.
Nigel
On 28/03/2012 04:14, Jason Weathersby wrote:
> Nigel,
> grouped his data.
> Jason
>> Hi Eric,
>> Nigel
>>> For the record:
Previous Topic:Using bindings in the expression editor?
Next Topic:How to get all default values of scalar parameter
Current Time: Sun Jul 20 03:36:58 EDT 2025
Powered by FUDForum. Page generated in 0.04301 seconds
