Home » Modeling » EMF » Customize code generation.
Customize code generation. [message #467994] Mon, 03 August 2009 10:43 Go to next message
Is there some tutorial on codegeneration customization? I.e. I have genmodel and when I click it I get all those editors/tests/commands/etc. How can I change the editor template?
I saw some generator plugin that generates validation adapter. But it looks like it only extends (i.e. adds) artifact generation while I want to customize persistence, editor code.
Re: Customize code generation. [message #468008 is a reply to message #467994] Mon, 03 August 2009 11:16 Go to previous messageGo to next message
--------------020409000907050504010704
Eugene,
If you want to customize what's already generated you can use dynamic
templates:
http://wiki.eclipse.org/index.php/EMF/FAQ#What_are_Dynamic_T emplates.3F
If you want to generate other/additional artifacts, the generator
example is good to look at.
Unless you generated many editors, it's not so clear you'd not be better
off simply specializing the generated editor. In terms of persistence,
it's probably generally better to focus persistence on using reflection
so that no model-specific things need to be generated...
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Eugene,<br>
<br>
templates:<br>
<blockquote><a
href=" http://wiki.eclipse.org/index.php/EMF/FAQ#What_are_Dynamic_T emplates.3F"> http://wiki.eclipse.org/index.php/EMF/FAQ#What_are_Dynamic_T emplates.3F</a><br>
</blockquote>
example is good to look at.<br>
<br>
better off simply specializing the generated editor.  In terms of
persistence, it's probably generally better to focus persistence on
using reflection so that no model-specific things need to be
generated...<br>
<br>
<br>
<blockquote cite="mid:h56t3d$f8m$1@build.eclipse.org" type="cite">Is
<br>
<br>
</blockquote>
</body>
</html>
--------------020409000907050504010704--
Re: Customize code generation. [message #468014 is a reply to message #468008] Mon, 03 August 2009 11:30 Go to previous message
Ed, thanks for the reply. I'll try the approach illustrated on the link.
Yes, I need to customize the editor generation - I'm trying to create a codegenerator that can generate some specific editors from the model - I need lots of those Smile
Previous Topic:Multivalued feature names
Next Topic:[Teneo] Undo / Redo resource save issue
Current Time: Sun Jul 20 06:17:51 EDT 2025
Powered by FUDForum. Page generated in 0.02975 seconds
