Home » Eclipse Projects » Rich Client Platform (RCP) » Drag and Drop in CommonNavigator
Drag and Drop in CommonNavigator [message #467472] Fri, 04 May 2007 07:45 Go to next message
I'm implementing Drag and Drop in CommonNavigator. So far I have
created a transfer data type, a Drag/DropAdapterAssistant and
configured everything in plugin.xml. I have a navigator view
with a working DragAdapterAssistant returning the array of
transfer types. But my DropAdapterAssistant isn't working. I expect
validateDrop() to be called when dragging the cursor over an
eligible targent node or at least when releasing the mouse button.
But nothing happens although the target node is in possibleChildren
and in possibleDropTargets. Any hints what's wrong and what to check?
Thanks in advance for your help.
Gruesse/Regards,
Peter Maas, Aachen
E-mail "cC5tYWFzQG1hZ21hc29mdC5kZQ==\n".decode("base64")
Re: Drag and Drop in CommonNavigator [message #467479 is a reply to message #467472] Fri, 04 May 2007 09:05 Go to previous messageGo to next message
Originally posted by: gsmithfarmer.gmail.com
I am trying the same (in an RCP application).
Did you supply both possibleChildren (to the contentProvider)
and possibleDropTargets to the dropAssistant? My drop assistant is being invoked...my problem is that I do not understand the transferData.
usine 3.2.2
Re: Drag and Drop in CommonNavigator [message #467491 is a reply to message #467479] Fri, 04 May 2007 10:01 Go to previous message
I supplied the target node type to navigatorContent/possibleChildren/instanceof
*and* to navigatorContent/dropAssistant/possibleDropTargets/instanceo f (both in
org.eclipse.ui.navigator.navigatorContent).
Then please tell me what you did that I forgot :)
There is a good article in the Eclipse articles collection:
http://www.eclipse.org/articles/Article-Workbench-DND/drag_d rop.html
You have to serialize the transferred selection on the drag side
(i.e. convert its objects to a byte array) and deserialize it on the
drop side (rebuild the selection objects from the byte array). This
is done in toByteArray() and fromByteArray().
Check out the running example at
http://www.eclipse.org/articles/Article-Workbench-DND/gadget src.zip
Gruesse/Regards,
Peter Maas, Aachen
Previous Topic:Field Decorators in Fomrs
Next Topic:Build Update Site
Current Time: Sun Jul 20 10:36:28 EDT 2025
Powered by FUDForum. Page generated in 0.04055 seconds
