Home » Eclipse Projects » Standard Widget Toolkit (SWT) » createPartControl
createPartControl [message #467018] Sun, 22 January 2006 20:25 Go to next message
Originally posted by: mohansl.gmail.com
I wish to call a view as follows(basically to set view content and open
it in performFinish of wizard) :
IWorkbenchWindow wdc =
PlatformUI.getWorkbench().getActiveWorkbenchWindow();
IWorkbenchPage page = wdc.getActivePage();
MyView myview = new MyView(viewContent);
myview.createPartControl(parent);
IViewPart part =(IViewPart) myview.getViewSite() ;
page.activate(part) ;
However how do I set the 'parent' in myview.createPartControl(parent)?
mohansl
Re: createPartControl [message #467020 is a reply to message #467018] Sun, 22 January 2006 23:08 Go to previous messageGo to next message
declare views extension point and open view
with page#showView
eclipes will create view for you
mohansl wrote:
> Regards,
> mohansl
Re: createPartControl [message #467022 is a reply to message #467020] Sun, 22 January 2006 22:34 Go to previous messageGo to next message
I could do that, however I wish to set the view content from the wizard
via the view constructor and then show the view, So how do I go about
doing it?
mohansl
Re: createPartControl [message #467026 is a reply to message #467018] Mon, 23 January 2006 10:12 Go to previous messageGo to next message
mohansl wrote:
> open it in performFinish of wizard) :
The short answer is you can't. Views don't work that way.
Your best bet is to have your view start up with a blank screen or
message (like the Content Outline view) and respond to another message
that causes it to update it's contents. ex:
IViewPart part = page.showView("id");
// the view now updates its composites
part.setViewContents(viewContent);
page.activate(part); // probably not necessary
The other (less good :-) option would be to have your performFinish()
put something in a singleton somewhere, and have your view always check
for information in it's IViewPart#init(*) method when it starts up.
Later,
PW
Re: createPartControl [message #467034 is a reply to message #467022] Mon, 23 January 2006 10:51 Go to previous messageGo to next message
You should ask this question in the eclipse.platform newsgroup:
news://news.eclipse.org/eclipse.platform
"mohansl" <mohansl@gmail.com> wrote in message
news:adb8cb97e28c979b35c1d362e4f5ea99$1@www.eclipse.org...
> doing it?
> Regards,
> mohansl
Re: createPartControl [message #467041 is a reply to message #467026] Mon, 23 January 2006 12:25 Go to previous message
Thanks, I got it working on lines of your snippet.
Thanks and Regards,
mohansl
Previous Topic:How to add a new Node the Tree Viewer available in Plugin from its Fragment
Next Topic:sizing Text
Current Time: Sat Jul 19 06:05:22 EDT 2025
Powered by FUDForum. Page generated in 0.05675 seconds
