Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Could any find the error in this piece of code
Could any find the error in this piece of code [message #466362] Mon, 09 January 2006 08:37 Go to next message
In this piece of code, I tried to create a table inside a Group,but this
table is not getting visible when I run it.
Please could any one say wats wrong in this code
// Code Start
package screens;
import org.eclipse.swt.SWT;
import org.eclipse.swt.custom.CLabel;
import org.eclipse.swt.custom.CTabFolder;
import org.eclipse.swt.custom.CTabItem;
import org.eclipse.swt.custom.StyledText;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Group;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.Table;
import org.eclipse.swt.widgets.TableColumn;
import org.eclipse.swt.widgets.TableItem;
public class CategorySelectionScr extends Shell {
* Launch the application
* @param args
public static void main(String args[]) {
try {
Display display = Display.getDefault();
CategorySelectionScr shell = new CategorySelectionScr(display,
SWT.SHELL_TRIM);
shell.open();
shell.layout();
while (!shell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep();
} catch (Exception e) {
e.printStackTrace();
* Create the shell
* @param display
* @param style
public CategorySelectionScr(Display display, int style) {
super(display, style);
createContents();
* Create contents of the window
protected void createContents() {
setText("SWT Application");
setSize(727, 521);
final Composite composite = new Composite(this, SWT.NONE);
composite.setBounds(0, 0, 716, 483);
final Composite composite_1 = new Composite(composite, SWT.NONE);
composite_1.setBounds(5, 25, 214, 455);
final Group selectCategoryGroup = new Group(composite_1, SWT.NONE);
selectCategoryGroup.setText("Select Category");
selectCategoryGroup.setBounds(5, 5, 205, 155);
final CLabel lblcategory = new CLabel(selectCategoryGroup, SWT.NONE);
lblcategory.setAlignment(SWT.RIGHT);
lblcategory.setText("Category");
lblcategory.setBounds(10, 20, 60, 20);
final StyledText styledText = new StyledText(selectCategoryGroup,
SWT.BORDER);
styledText.setBounds(80, 21, 115, 19);
final Button searchButton = new Button(selectCategoryGroup, SWT.NONE);
searchButton.setText("Search");
searchButton.setBounds(110, 55, 90, 30);
final CTabFolder tabFolder = new CTabFolder(composite, SWT.NONE);
tabFolder.setMRUVisible(true);
tabFolder.setBounds(223, 25, 490, 453);
final CTabItem categoryListTabItem = new CTabItem(tabFolder, SWT.NONE);
categoryListTabItem.setText("Category List");
final Group categoryListGroup = new Group(tabFolder, SWT.NONE);
categoryListGroup.setText("Category List");
categoryListTabItem.setControl(categoryListGroup);
final Table table = new Table(categoryListGroup, SWT.BORDER | SWT.RADIO);
table.setLinesVisible(true);
table.setHeaderVisible(true);
table.setBounds(10, 20, 459, 240);
final TableColumn tc1 = new TableColumn(table, SWT.LEFT);
final TableColumn tc2 = new TableColumn(table, SWT.CENTER);
final TableColumn tc3 = new TableColumn(table, SWT.CENTER);
// final TableColumn tc4 = new TableColumn(table, SWT.CENTER);
tc1.setText("Category");
tc2.setText("Description");
tc3.setText("Slot");
// tc4.setText("Slot");
tc1.setWidth(40);
tc2.setWidth(70);
tc3.setWidth(80);
// tc4.setWidth(70);
final TableItem item1 = new TableItem(table, SWT.NONE);
item1.setText(new String[] { "Radio", "Radio with FM", "Radio" });
final TableItem item2 = new TableItem(table, SWT.NONE);
item2.setText(new String[] { "Fahrersitz", "Fahrersitz", "Fahrersitz"
//@Override
protected void checkSubclass() {
// Code Ends
Thanks and Regards,
Neel
Re: Could any find the error in this piece of code [message #466363 is a reply to message #466362] Mon, 09 January 2006 09:10 Go to previous messageGo to next message
Originally posted by: f.fankhauser.gmx.at
Hi Neel,
class Shell cannot be extended.
From the swt docs for Shell: IMPORTANT: This class is not intended to be
subclassed.
Florian
Neel schrieb:
> this table is not getting visible when I run it.
> // Code Start
> package screens;
> import org.eclipse.swt.widgets.Display;
> * @param args
> try {
> SWT.SHELL_TRIM);
> shell.open();
> shell.layout();
> display.sleep();
> * Create the shell
> * @param display
> * @param style
> createContents();
> setSize(727, 521);
> SWT.NONE);
> SWT.NONE);
> StyledText(selectCategoryGroup, SWT.BORDER);
> SWT.NONE);
> SWT.NONE);
> SWT.RADIO);
> tc1.setWidth(40);
> tc2.setWidth(70);
> tc3.setWidth(80);
> "Fahrersitz" });
> //@Override
> // Code Ends
> Thanks and Regards,
> Neel
Re: Could any find the error in this piece of code [message #466366 is a reply to message #466362] Mon, 09 January 2006 09:50 Go to previous messageGo to next message
Extending Shell doesn't seem to be the issue here. You didn't use any of the non-public API and you properly overrode the checkSubclass() method. I would suggest that you rewrite this so that you extend Composite rather than Shell and then use composition to control the shell instance, but it isn't required for the code to work.
It would seem that you're using absolute positioning (setBounds(int, int, int, int)) rather than a layout manager. I *strongly* advice against this and honestly, I think it's probably your problem. I know that it's possible to do this and many people have, but it's not a good idea. Preferred and minimum sizes vary greatly from platform to platform. You'll find that while this layout may work on Windows, it probably won't work very well on Mac OS X. And while it might work in Bluecurve themed GTK+, it almost certainly won't work if you go to the most recent build of Clearlooks. Try changing the code to use a layout manager and I bet your problem solves itself. :-)
Re: Could any find the error in this piece of code [message #466383 is a reply to message #466362] Mon, 09 January 2006 17:12 Go to previous message
Call tabFolder.setBounds(223, 25, 490, 453) after calling
categoryListTabItem.setControl(categoryListGroup).
"Neel" <neelakantan_k@infosys.com> wrote in message
news:bfd2ce5b03bef267e1217cc74faae8ff$1@www.eclipse.org...
> // Code Start
> package screens;
> * @param args
> try {
> SWT.SHELL_TRIM);
> shell.open();
> shell.layout();
> display.sleep();
> * Create the shell
> * @param display
> * @param style
> createContents();
> setSize(727, 521);
> SWT.BORDER);
> tc1.setWidth(40);
> tc2.setWidth(70);
> tc3.setWidth(80);
> "Fahrersitz" });
> //@Override
> // Code Ends
> Thanks and Regards,
> Neel
Previous Topic:Few questions
Next Topic:How to rotate an image?
Current Time: Sat Jul 19 13:40:07 EDT 2025
Powered by FUDForum. Page generated in 2.47842 seconds
