Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Could any find the error in this piece of code
Could any find the error in this piece of code [message #466362] |
Mon, 09 January 2006 08:37  |
In this piece of code, I tried to create a table inside a Group,but this
table is not getting visible when I run it.
Please could any one say wats wrong in this code
// Code Start
package screens;
import org.eclipse.swt.SWT;
import org.eclipse.swt.custom.CLabel;
import org.eclipse.swt.custom.CTabFolder;
import org.eclipse.swt.custom.CTabItem;
import org.eclipse.swt.custom.StyledText;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Group;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.Table;
import org.eclipse.swt.widgets.TableColumn;
import org.eclipse.swt.widgets.TableItem;
public class CategorySelectionScr extends Shell {
* Launch the application
* @param args
public static void main(String args[]) {
try {
Display display = Display.getDefault();
CategorySelectionScr shell = new CategorySelectionScr(display,
SWT.SHELL_TRIM);
shell.open();
shell.layout();
while (!shell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep();
} catch (Exception e) {
e.printStackTrace();
* Create the shell
* @param display
* @param style
public CategorySelectionScr(Display display, int style) {
super(display, style);
createContents();
* Create contents of the window
protected void createContents() {
setText("SWT Application");
setSize(727, 521);
final Composite composite = new Composite(this, SWT.NONE);
composite.setBounds(0, 0, 716, 483);
final Composite composite_1 = new Composite(composite, SWT.NONE);
composite_1.setBounds(5, 25, 214, 455);
final Group selectCategoryGroup = new Group(composite_1, SWT.NONE);
selectCategoryGroup.setText("Select Category");
selectCategoryGroup.setBounds(5, 5, 205, 155);
final CLabel lblcategory = new CLabel(selectCategoryGroup, SWT.NONE);
lblcategory.setAlignment(SWT.RIGHT);
lblcategory.setText("Category");
lblcategory.setBounds(10, 20, 60, 20);
final StyledText styledText = new StyledText(selectCategoryGroup,
SWT.BORDER);
styledText.setBounds(80, 21, 115, 19);
final Button searchButton = new Button(selectCategoryGroup, SWT.NONE);
searchButton.setText("Search");
searchButton.setBounds(110, 55, 90, 30);
final CTabFolder tabFolder = new CTabFolder(composite, SWT.NONE);
tabFolder.setMRUVisible(true);
tabFolder.setBounds(223, 25, 490, 453);
final CTabItem categoryListTabItem = new CTabItem(tabFolder, SWT.NONE);
categoryListTabItem.setText("Category List");
final Group categoryListGroup = new Group(tabFolder, SWT.NONE);
categoryListGroup.setText("Category List");
categoryListTabItem.setControl(categoryListGroup);
final Table table = new Table(categoryListGroup, SWT.BORDER | SWT.RADIO);
table.setLinesVisible(true);
table.setHeaderVisible(true);
table.setBounds(10, 20, 459, 240);
final TableColumn tc1 = new TableColumn(table, SWT.LEFT);
final TableColumn tc2 = new TableColumn(table, SWT.CENTER);
final TableColumn tc3 = new TableColumn(table, SWT.CENTER);
// final TableColumn tc4 = new TableColumn(table, SWT.CENTER);
tc1.setText("Category");
tc2.setText("Description");
tc3.setText("Slot");
// tc4.setText("Slot");
tc1.setWidth(40);
tc2.setWidth(70);
tc3.setWidth(80);
// tc4.setWidth(70);
final TableItem item1 = new TableItem(table, SWT.NONE);
item1.setText(new String[] { "Radio", "Radio with FM", "Radio" });
final TableItem item2 = new TableItem(table, SWT.NONE);
item2.setText(new String[] { "Fahrersitz", "Fahrersitz", "Fahrersitz"
//@Override
protected void checkSubclass() {
// Code Ends
Thanks and Regards,
Neel
Re: Could any find the error in this piece of code [message #466363 is a reply to message #466362] |
Mon, 09 January 2006 09:10   |
Originally posted by: f.fankhauser.gmx.at
Hi Neel,
class Shell cannot be extended.
From the swt docs for Shell: IMPORTANT: This class is not intended to be
subclassed.
Florian
Neel schrieb:
> this table is not getting visible when I run it.
> // Code Start
> package screens;
> import org.eclipse.swt.widgets.Display;
> * @param args
> try {
> SWT.SHELL_TRIM);
> shell.open();
> shell.layout();
> display.sleep();
> * Create the shell
> * @param display
> * @param style
> createContents();
> setSize(727, 521);
> SWT.NONE);
> SWT.NONE);
> StyledText(selectCategoryGroup, SWT.BORDER);
> SWT.NONE);
> SWT.NONE);
> SWT.RADIO);
> tc1.setWidth(40);
> tc2.setWidth(70);
> tc3.setWidth(80);
> "Fahrersitz" });
> //@Override
> // Code Ends
> Thanks and Regards,
> Neel
Re: Could any find the error in this piece of code [message #466383 is a reply to message #466362] |
Mon, 09 January 2006 17:12  |
Call tabFolder.setBounds(223, 25, 490, 453) after calling
categoryListTabItem.setControl(categoryListGroup).
"Neel" <neelakantan_k@infosys.com> wrote in message
news:bfd2ce5b03bef267e1217cc74faae8ff$1@www.eclipse.org...
> // Code Start
> package screens;
> * @param args
> try {
> SWT.SHELL_TRIM);
> shell.open();
> shell.layout();
> display.sleep();
> * Create the shell
> * @param display
> * @param style
> createContents();
> setSize(727, 521);
> SWT.BORDER);
> tc1.setWidth(40);
> tc2.setWidth(70);
> tc3.setWidth(80);
> "Fahrersitz" });
> //@Override
> // Code Ends
> Thanks and Regards,
> Neel
Current Time: Sat Jul 19 22:01:13 EDT 2025
Powered by FUDForum. Page generated in 0.22450 seconds
