Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Multiple DropTargets
Multiple DropTargets [message #465644] Thu, 15 December 2005 20:32 Go to next message
Originally posted by: dank.webreachinc.com
I have droptarget 1 and 2. I have dragsource 1 and 2. You can drag from
1 to 1 and from 2 to 2 but not 1 to 2 or 2 to 1 (when talking about
sources and targets respectively). In the drop method, I can check the
event.data to make sure that this action is ignored if incorrect but the
cursor still shows up as a valid drop point. I'd like the cursor to turn
into the circle with a line through it if you drag 1 to 2.
This should be as simple as checking the event.data in the dragOver()
method (or any of the other provided methods I can implement), but for
some reason the event.data is always null in these methods. Therefore I'm
stumped. I don't know how to accomplish this task.
Dan
Re: Multiple DropTargets [message #465717 is a reply to message #465644] Tue, 20 December 2005 07:43 Go to previous message
See DropTarget section of :
http://eclipse.org/articles/Article-SWT-DND/DND-in-SWT.html
What you are trying to do is only supported on Windows:
public void dragOver(DropTargetEvent event) {
event.feedback = DND.FEEDBACK_SELECT | DND.FEEDBACK_SCROLL;
if (textTransfer.isSupportedType(event.currentDataType)) {
// NOTE: on unsupported platforms this will return null
Object o = textTransfer.nativeToJava(event.currentDataType);
String t = (String)o;
if (t != null) System.out.println(t);
"Daniel Kaplan" <dank@webreachinc.com> wrote in message
news:d1c01b8cff1bcfa50613428bcf30995d$1@www.eclipse.org...
>I have droptarget 1 and 2. I have dragsource 1 and 2. You can drag from 1
>to 1 and from 2 to 2 but not 1 to 2 or 2 to 1 (when talking about sources
>and targets respectively). In the drop method, I can check the event.data
>to make sure that this action is ignored if incorrect but the cursor still
>shows up as a valid drop point. I'd like the cursor to turn into the
> Dan
Previous Topic:Need help with a Property Editor using Tree.
Next Topic:scrollbars are not moving using mouse wheels
Current Time: Sat Jul 19 04:59:24 EDT 2025
Powered by FUDForum. Page generated in 0.04200 seconds
