Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Adding a scroll to the Composite widget
Adding a scroll to the Composite widget [message #465451] Tue, 13 December 2005 23:18 Go to next message
Hi guys,
I'm looking to add a scroll to a Composite widget similar to the
ScrolledComposite, but I want to use a GridLayout for laying out controls
within the composite.
I'm just wondering if this has already been done. Also. Where would you guys
recommend I start? The way I see it the best way would be to extend the
ScrolledCompositeLayout such that it applys a grid layout.. Or my other
option is to extend the Composite and include what's needed to control the
scroll bars..
Can anyone think of a better way of going about this?
Thanks in advance,
Joe
Re: Adding a scroll to the Composite widget [message #465452 is a reply to message #465451] Tue, 13 December 2005 23:25 Go to previous messageGo to next message
Thinking about it a little more.. Will this work:
1) create a ScrolledComposite with both scrollbars
2) create a Composite with the GridLayout using the ScrolledComposite as
it's parent
3) add my controls to the Composite.
I can't really think of a reason that it shouldn't.. but I'm pretty new to
SWT and would appreciate any suggestions,
Thanks in advance,
Joe
Re: Adding a scroll to the Composite widget [message #465456 is a reply to message #465452] Wed, 14 December 2005 03:23 Go to previous message
Originally posted by: friederich.kupzog.de
Hi, this is ablsolutely right, but you are missing a few things.
Have a look into the Java doc for ScrolledComposite. You will see that
you have to call scrolledComposite.setContent() (I think) and
gridLayoutComposite.setSize() (I am sure).
Hope that helped,
Friederich
> it's parent
> Thanks in advance,
> Joe
Friederich Kupzog
Elektronik & Software
Neusser Str. 5-7
50670 Köln
Tel +49 241 9979356
Fax +49 221 726670
www.kupzog.de/fkmk
Previous Topic:Using ScrolledComposite on the J9 JVM
Next Topic:How to define each column's width in a GridLayout?
Current Time: Sat Jul 19 08:24:53 EDT 2025
Powered by FUDForum. Page generated in 0.02918 seconds
