Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Composite Sizes
Composite Sizes [message #465047] Sun, 04 December 2005 13:29 Go to next message
Originally posted by: eskay187.sbox.tugraz.at
<noob>
Hi.
I've created a Composite which contains a TableViewer and a Lable
(status text etc.) but i have the problem that whenever i set a
GridLayout the TableViewer gets very small and i have to resize
every value manually.
So i tried FillLayout, which sets the acorrect size to the TableViewer
but the label is large as the TableViewer.
I tried to put each into it's own composite but still the label is too
large, even when i try to set the soizes manually.
Could please someone look quickly through the code and help me ?
public void createPartControl(Composite parent)
// set display
display_= parent.getDisplay();
// create new table viewer
Composite viewer = new Composite(parent, SWT.NONE);
FillLayout fill = new FillLayout (SWT.VERTICAL);
viewer.setLayout(fill);
viewer.setVisible(true);
viewer_ = new TableViewer(viewer, SWT.TOP | SWT.SINGLE | SWT.V_SCROLL);
// SOME VIEWER_ STUFF HERE
Composite test = new Composite (parent, SWT.NONE);
label_ = new Label(test, SWT.HORIZONTAL);
label_.setText("test");
//label_.setFont(font_registry_.get("list"));
label_.pack();
test.pack();
test.setVisible(true);
label_.setVisible(true);
FillLayout grid = new FillLayout (SWT.VERTICAL);
parent.setLayout(grid);
Kind Regards
Helmut
</noob>
Re: Composite Sizes [message #465058 is a reply to message #465047] Sun, 04 December 2005 23:52 Go to previous messageGo to next message
Originally posted by: osipov.appliedtech.ru
Anyway, try something like this. I use gridData usually. Actually, you don't
need those size hints. If something like you've described is happening, i.e.
you've messed something with layouts.
// set display
parent.setLayout(new GridLayout());
parent.setLayoutData(new GridData(GridData.FILL_BOTH));
viewer = new TableViewer(viewer, SWT.TOP | SWT.SINGLE | SWT.V_SCROLL);
GridData gridData = new GridData(GridData.FILL_BOTH);
gridData.widthHint = 300;
gridData.heightHint = 300;
viewer.setLayoutData(gridData);
> Hi.
> // set display
> label_.pack();
> test.pack();
> Kind Regards
> Helmut
> </noob>
Re: Composite Sizes [message #465065 is a reply to message #465058] Mon, 05 December 2005 02:46 Go to previous message
Hi!
Thank you for your answer, it works better now. I copied your solution
and the sizes of the comosites are perfect, but the label and the
tableviewer did have 0 sizes until i set them manually.
unfortunately the tableviewer "lost" the vertical scrollbar, and the
composite's doesn't work on the viewer. help ?
can i get the size of the view ? parent->size returns 0 (i guess this is
when everthing is constructed -> resizeeventhandler?)
thanks again
helmut
> // set display
>>Hi.
>>// set display
>> label_.pack();
>>test.pack();
>>Kind Regards
>>Helmut
>></noob>
Previous Topic:Can I do custom painting of a widget on the Workbench?
Next Topic:libflashplayer inside browser component
Current Time: Sun Jul 20 14:26:33 EDT 2025
Powered by FUDForum. Page generated in 0.03787 seconds
