React to closing of an editor [message #463794] |
Thu, 15 February 2007 12:07  |
i have written a rcp-application where i open an editor. When this editor
is closed i want certain things in my workbench to be updated. For this i
have written a method in my core-plugin that does this updating. I need
this method in a lot of situations, thatŽs why it has to be in this
central location.
The problem is, that the editor is opend via an actionSet that is a
contribution from another plugin. And this plugin is not allowed to call
code from the core-plugin (only the other way around). So how can i
achieve that my update-method is called after my editor is closed? The
only connection to the editor in my core-plugin is a GroupMarker in my
MenuManager that acts as a placeholder for the actionSet contributed by
the other plugin. But i canŽt stick any listeners to that. How can react
to the Event of the menu- and toolbar-items beeing selected?
Or what else can i do?
Thanks for any help.
Peter
Re: React to closing of an editor [message #464989 is a reply to message #463794] |
Wed, 21 March 2007 10:09  |
Peter,
I'm confused by one of your statements. You said that the contributing plug-in is not allowed to call any code in the core plug-in, only the other way around. But that to me is backwards. Your core plug-in shouldn't depend on any code in contributing plug-ins...however, on the flipside, a contributing plug-in should be able to depend on the "core" plug-in.
So, in your situation, I would think that the core plug-in would expose the code needed to perform your work and then the contributing plug-in would create a dependency on the core. If it truly is the "core", then all plug-ins around it should need that "core" code.
I'm not really sure how you would do it otherwise, without duplicating code.
Just my two cents.
FUDForum. Page generated in 0.07681 seconds
