TableTreeViewer support for the new tree table widget [message #464706] |
Mon, 28 November 2005 20:42  |
I recall this hasn't been done but like to make sure. With now the Tree
widget supporting multiple columns and thus making TableTree class
depreciated, is there an equivalent viewer support of TableTreeViewer from
jface side, or will I need to construct and update the TreeItem nodes
manually? Thanks.
Michael
Re: TableTreeViewer support for the new tree table widget [message #464777 is a reply to message #464706] |
Tue, 29 November 2005 13:19   |
import java.io.*;
import java.util.*;
import org.eclipse.jface.viewers.*;
import org.eclipse.swt.*;
import org.eclipse.swt.graphics.*;
import org.eclipse.swt.layout.*;
import org.eclipse.swt.program.*;
import org.eclipse.swt.widgets.*;
public class TreeViewerTest {
class TreeViewerTestLabelProvider implements ITableLabelProvider,
ITableColorProvider, ITableFontProvider {
Font font = null;
public String getColumnText(Object element, int columnIndex) {
if (!(element instanceof File)) return null;
File file = (File)element;
switch (columnIndex) {
case 0:
return file.getName();
case 1:
return ""+new Date(file.lastModified());
case 2:
return ""+file.isHidden();
return null;
public Image getColumnImage(Object element, int columnIndex) {
if (columnIndex != 0) return null;
Display display = Display.getCurrent();
if (file.isDirectory()) return
display.getSystemImage(SWT.ICON_WARNING);
return display.getSystemImage(SWT.ICON_QUESTION);
public void dispose() {
if (font != null) font.dispose();
font = null;
public boolean isLabelProperty(Object element, String
property) {
return false;
public void addListener(ILabelProviderListener listener) {
public void removeListener(ILabelProviderListener listener) {
public Color getForeground(Object element, int columnIndex) {
if (columnIndex == 1) {
return display.getSystemColor(SWT.COLOR_RED);
return null;
public Color getBackground(Object element, int columnIndex) {
if (columnIndex == 0) {
display.getSystemColor(SWT.COLOR_CYAN);
return
display.getSystemColor(SWT.COLOR_MAGENTA);
return null;
public Font getFont(Object element, int columnIndex) {
if (columnIndex == 2) {
if (font == null) {
font = new Font(display, "Times", 12,
SWT.ITALIC);
return font;
return null;
final Display display = new Display();
final Shell shell = new Shell(display);
shell.setLayout(new FormLayout());
TreeViewerTestLabelProvider labelProvider1 = new TreeViewerTest().new
TreeViewerTestLabelProvider();
ITreeContentProvider contentProvider = new ITreeContentProvider() {
public Object[] getChildren(Object parentElement) {
if (!(parentElement instanceof File)) return null;
File file = (File)parentElement;
if (file.isDirectory()) return file.listFiles();
return null;
public Object getParent(Object element) {
return file.getParentFile();
public boolean hasChildren(Object element) {
if (!(element instanceof File)) return false;
return file.isDirectory();
public Object[] getElements(Object inputElement) {
return getChildren(inputElement);
public void inputChanged(Viewer viewer, Object oldInput,
Object newInput) {
ILabelProvider labelProvider2 = new ILabelProvider() {
property) {
return false;
public Image getImage(Object element) {
public String getText(Object element) {
final TreeViewer treeViewer1 = new TreeViewer(shell,
SWT.FULL_SELECTION | SWT.CHECK);
Tree tree1 = treeViewer1.getTree();
tree1.setHeaderVisible(true);
TreeColumn column1 = new TreeColumn(tree1, SWT.LEFT);
column1.setText("Name");
column1.setImage(display.getSystemImage(SWT.ICON_WORKING));
column1.setWidth(200);
TreeColumn column2 = new TreeColumn(tree1, SWT.CENTER);
column2.setText("Last Modified");
column2.setImage(display.getSystemImage(SWT.ICON_INFORMATION ));
column2.setWidth(200);
TreeColumn column3 = new TreeColumn(tree1, SWT.CENTER);
column3.setText("Hidden");
column3.setImage(display.getSystemImage(SWT.ICON_INFORMATION ));
column3.setWidth(100);
treeViewer1.setLabelProvider(labelProvider1);
treeViewer1.setContentProvider(contentProvider);
final TreeViewer treeViewer2 = new TreeViewer(shell);
Tree tree2 = treeViewer2.getTree();
treeViewer2.setLabelProvider(labelProvider2);
treeViewer2.setContentProvider(contentProvider);
Button b = new Button(shell, SWT.PUSH);
b.setText("choose root folder");
b.addListener(SWT.Selection, new Listener() {
public void handleEvent(Event e) {
DirectoryDialog f = new DirectoryDialog(shell,
SWT.OPEN);
String root = f.open();
if (root != null) {
File file = new File(root);
if (file.exists()) {
treeViewer1.setInput(file);
treeViewer1.refresh();
treeViewer2.setInput(file);
treeViewer2.refresh();
FormData data = new FormData();
data.left = new FormAttachment(0, 10);
data.top = new FormAttachment(0, 10);
data.right = new FormAttachment(50, -5);
data.bottom = new FormAttachment(b, -10);
tree1.setLayoutData(data);
data.left = new FormAttachment(50, 5);
data.right = new FormAttachment(100, -10);
tree2.setLayoutData(data);
data.bottom = new FormAttachment(100, -10);
b.setLayoutData(data);
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep();
display.dispose();
FUDForum. Page generated in 0.03396 seconds
