RCP project - Multiple developers [message #464316] |
Thu, 01 March 2007 23:59  |
Originally posted by: partyhut.internode.on.net
Hi all,
I am not quite sure if this is the right place to ask this question but
since lots of you have real project experience, I hope you can shed some
light on this issue.
We are going to start a RCP project. The project is big and there will
be many programmers working on it. We are planing to use Eclipse with
CVS or SVN for source management. We are trying to allow people check
out as few files as possible (only files they need to change) and then
test the change against a central file repository. This will make sure
the change always work with the latest version of the system (other
people might change other subsystem anytime)... Is this achievable? If
yes, How do I setup eclipse and the project folder structure? Thank you
in advance.
Henry
Re: RCP project - Multiple developers [message #465172 is a reply to message #464437] |
Sat, 24 March 2007 11:36  |
Michael Spector schrieb:
> HS wrote:
>> Hi Michael,
>> Thank you for your prompt answer. I guess my real question is:
>> We will have multiple developers (1-3 ppl) work on each plug-ins and
>> plug-ins rely heavily on other plug-ins to work correctly. When
>> developing we would like to always test our work with the newest version
>> of other plug-ins constantly updated by other development group.
> I think a good technique may be:
> 1) Work on concrete module of the system, fix bugs, write Unit tests.
> 2) Update from CVS a local copy of the whole system.
> 3) Run Unit tests.
> 4) If there are failures (especially regression failures) - return to the
> first step, otherwise - commit your changes.
>> It
>> would be great if our developers don't need to keep a local copy
>> (checked out from CVS) of the system as it might already changed. Also,
>> checking out every time before testing is painful. My knowledge of Unit
>> Testing is limited. I was thinking maybe all developers can test their
>> plug-in with a centralized copy of the latest system(from CVS) instead
>> of each one has a local copy of some old version.
> Then, you can run a nightly test on a centralized copy, if it's not critical
> that untested code is committed...
My suggestion is to let a programmer check out the minimal set of
required plugins needed to compile the plugin he is working on.
Next steps are writing code and unit tests as well as running them on
the minimal local plugin set.
In our team we are using cruisecontrol
(http://cruisecontrol.sourceforge.net/) for continuous integration of
the whole system. You can use cruiscontrol to run tests on the whole
system continuously and let the developers being notified via email or
html-interface if builds are failed or tests went wrong.
cheers
Armin
FUDForum. Page generated in 0.34391 seconds
