Home » Eclipse Projects » Rich Client Platform (RCP) » Problems when creating a new project when running a RCP product
Problems when creating a new project when running a RCP product [message #464141] Mon, 26 February 2007 14:09
Originally posted by: zivzeira.yahoo.com
Let me rephrase...
The following refers to an attempt to create a product (RCP).
I am having problems when I open a NEW project (no matter whether a simple
project or a custom project).
It actually occurs when I run the RCP in debug mode when I configure the
"Eclipse application" --> "Program To Run" --> "Run a product" to run my
RCP.
When I activate the Navigator view (as can be seen on the attached file) it
presents a faulty result.
The same is with the Package Explorer view.
Any help would be appreciated.
Thanks in advance,
Ziv.
> "Ziv Zeira" <zivzeira@yahoo.com> wrote in message
> news:erunab$bbh$1@utils.eclipse.org...
>> Hello,
>> I'm working with Eclipse 3.1.2 (Build id: M20060118-1600) on a product
>> development.
>> When I create a project with some content in the following way:
>> IProject project = super.getNewProject();
>> IFolder folder = project.getFolder("folder1");
>> folder.create(true, true, null);
>> folder.getFolder(new Path("subFolder).create(true, true, null);
>> IFile file = project.getFile(new Path(fileName));
>> Everything work fine as i run the product as an org.eclipse.sdk.ide
>> product.
>> But when I am running the product as his product configuration the
>> resource
>> navigator doesn't show the project name or his simple project image icon
>> or
>> his sub content (and their image icons).
>> The package explorer shows the sub content branches but without the sub
>> folders and project names and their images.
>> The package explorer shows do show the files naming and their images
>> icons
>> (maybe since the image are loaded by the product).
>> when creating java project the product fail with the following exception:
>> org.eclipse.jface.util.Assert$AssertionFailedException: null argument;
>> at org.eclipse.jface.util.Assert.isNotNull(Assert.java:149)
>> at org.eclipse.jface.util.Assert.isNotNull(Assert.java:125)
>> at
>> org.eclipse.jdt.ui.JavaElementImageDescriptor.<init>(JavaElementImageDescriptor.java:88)
>> at
>> org.eclipse.jdt.internal.ui.viewsupport.JavaElementImageProv ider.getJavaImageDescriptor(JavaElementImageProvider.java:15 1)
>> at
>> org.eclipse.jdt.internal.ui.viewsupport.JavaElementImageProv ider.computeDescriptor(JavaElementImageProvider.java:111)
>> at
>> org.eclipse.jdt.internal.ui.viewsupport.JavaElementImageProv ider.getImageLabel(JavaElementImageProvider.java:92)
>> at
>> org.eclipse.jdt.internal.ui.viewsupport.JavaUILabelProvider. getImage(JavaUILabelProvider.java:138)
>> at
>> org.eclipse.jdt.internal.ui.wizards.buildpaths.newsourcepage .DialogPackageExplorer$PackageLabelProvider.getImage(DialogP ackageExplorer.java:221)
>> at
>> org.eclipse.jface.viewers.DecoratingLabelProvider.getImage(D ecoratingLabelProvider.java:82)
>> at
>> org.eclipse.jface.viewers.DecoratingLabelProvider.updateLabe l(DecoratingLabelProvider.java:212)
>> at
>> org.eclipse.jface.viewers.StructuredViewer.buildLabel(Struct uredViewer.java:1855)
>> at org.eclipse.jface.viewers.TreeViewer.doUpdateItem(TreeViewer .java:228)
>> at
>> org.eclipse.jface.viewers.AbstractTreeViewer$UpdateItemSafeR unnable.run
>> Thanks in advance :)
Previous Topic:No image icons or names in the resource navigator in a RCP product
Next Topic:Searching for RCPs on a local drive.
Current Time: Sat Jul 19 15:23:54 EDT 2025
Powered by FUDForum. Page generated in 0.04485 seconds
