Home » Eclipse Projects » Rich Client Platform (RCP) » Discouraged accesses - consequences?
Discouraged accesses - consequences? [message #463727] Thu, 15 February 2007 02:12 Go to next message
Originally posted by: unidad.gmx.net
Hi!
I'm quite new to the RCP-stuff and I'm developing
a little standalone-RCP-Application.
(Kind of a college term project)
I'm implementing several features and the whole thing evolves.
There's one point I'm not sure about. I have several warnings about
discouraged access:
e.g.:
Discouraged access: The type JavaFileEditorInput is not accessible due
to restriction on required library
C:\eclipse\eclipse321\plugins\org.eclipse.ui.editors_3.2.1.r 321_v20060721.jar
I assume, one should avoid discouraged accesses, but I can't see the
disadvantages if there are any.
Maybe one can clarify this a bit.
Greetings, Hermann
Re: Discouraged accesses - consequences? [message #463735 is a reply to message #463727] Thu, 15 February 2007 03:28 Go to previous messageGo to next message
Hermann Maier wrote:
> Hi!
> discouraged access:
> e.g.:
For example that this class will be deleted in 3.3 because it is an
internal class. If you use such a class today you can be broken tomorrow.
Dani
> Greetings, Hermann
Re: Discouraged accesses - consequences? [message #463742 is a reply to message #463735] Thu, 15 February 2007 03:48 Go to previous messageGo to next message
Hi Dani!
Daniel Megert schrieb:
[disadvantages discouraged accesses]
> Dani
Okay. That's no problem for me now.
I "deliver" a small standalone-Eclipse-3.2-RCP-App, based on fixed
sources. (It's no commercial thing.) If another one wants to migrate it
to be based on further Eclipse-versions, it's his problem. ;)
Of course this is very bad programming style. If I can avoid it, I would
like to.
Is "every functionality" also available through some public API?
For instance I use Eclipse 3.2 and want to save a file in a
"saveAs"-dialog outside the workspace. Is there perhaps another
"legal" way doing this in Eclipse 3.2 without using JavaFileEditorInput,
which provides the discouraged access?
(I've read your solution with Eclipse 3.3, but unless it's a stable
release, I won't try it. I've enough to do with this one. ;)
Greetings, Hermann
Re: Discouraged accesses - consequences? [message #463775 is a reply to message #463742] Thu, 15 February 2007 08:43 Go to previous messageGo to next message
No ... while all of the source is available for use, only certain parts
are public API.
It depends on what you want to do in your RCP. For example, you can
find the ActionFactory.SAVE_AS action and add that in your
ApplicationActionBarAdvisor, or use your own action and call the save as
command (the id can be found in the plug-in registry view,
org.eclipse.ui.file.saveAs).
But if you wanted to skip steps, like not have Save As pop open a
dialog, that you can't do without touching internal code.
Later,
PW
Re: Discouraged accesses - consequences? [message #463788 is a reply to message #463742] Thu, 15 February 2007 10:48 Go to previous messageGo to next message
> Hi Dani!
>> tomorrow.
>> Dani
> it to be based on further Eclipse-versions, it's his problem. ;)
> would like to.
No.
> JavaFileEditorInput, which provides the discouraged access?
Only by writing your own editor input.
> Greetings, Hermann
Re: Discouraged accesses - consequences? [message #463815 is a reply to message #463788] Thu, 15 February 2007 16:47 Go to previous messageGo to next message
Hi!
So, the cleanest solution would be, that I copy the source-code of
JavaFileEditorInput in one of my own classes and so the functionality
will persist, even if JavaFileEditorInput changes in underlying plugins?
Greetings, Hermann
Re: Discouraged accesses - consequences? [message #463821 is a reply to message #463815] Fri, 16 February 2007 03:01 Go to previous messageGo to next message
> Hi!
In your case where an API exists in the next version it makes more sense
to use the internal class in your 3.2.x based plug-in(s) and make a new
version for Eclipse 3.3 that uses the new FileStoreEditorInput API.
Dani
> Greetings, Hermann
Re: Discouraged accesses - consequences? [message #463823 is a reply to message #463821] Fri, 16 February 2007 03:38 Go to previous messageGo to next message
> Dani
Okay, thanks for your input!
Hermann
Re: Discouraged accesses - consequences? [message #463855 is a reply to message #463727] Fri, 16 February 2007 17:38 Go to previous messageGo to next message
Hermann,
Note that if your RCP application is running with the osgi framework in strict
mode (osgi.resolverMode=strict), then this would result in class not found
exceptions at runtime.
-Andrew
> Hi!
> discouraged access:
> e.g.:
> Greetings, Hermann
Re: Discouraged accesses - consequences? [message #463879 is a reply to message #463815] Mon, 19 February 2007 10:20 Go to previous message
Originally posted by: lamont_gilbert.rigidsoftware.com
On Thu, 15 Feb 2007 22:47:11 +0100, Hermann Maier wrote:
> Hi!
>>> "saveAs"-dialog outside the workspace. Is there perhaps another "legal"
>>> way doing this in Eclipse 3.2 without using JavaFileEditorInput, which
> JavaFileEditorInput in one of my own classes and so the functionality will
> Greetings, Hermann
The cleanest solution would be to implement your own version of
IEditorInput I have a JavaFileEditorInput myself and its rediculously
simple. Perhaps you can achieve that with simply copy from Eclipse.
Previous Topic:MasterDetailsBlock and visible actions
Next Topic:Adding a new context menu (not items to an existing)
Current Time: Sat Jul 19 14:57:27 EDT 2025
Powered by FUDForum. Page generated in 0.06372 seconds
