Home » Eclipse Projects » Standard Widget Toolkit (SWT) » problem with the cell size
problem with the cell size [message #462078] Wed, 05 October 2005 16:16 Go to next message
Originally posted by: jaguaralcon.hotmail.com
I has a proble with the following code.
Can you help me.
package phantom.prueba;
import org.eclipse.swt.SWT;
import org.eclipse.swt.graphics.Image;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.Table;
import org.eclipse.swt.widgets.TableColumn;
import org.eclipse.swt.widgets.Widget;
import phantom.core.GCustom;
* @author qjaime
* TODO To change the template for this generated type comment go to
* Window - Preferences - Java - Code Style - Code Templates
public class prueba_tabla2 {
public static Display myDisplay;
static final String NAME = "Directorio de Clientes";
Shell shell;
GridLayout layout = new GridLayout();
GridData tData = null;
Widget[] control = new Widget[3];
public prueba_tabla2()
myDisplay = new Display();
shell = new Shell(myDisplay,SWT.CLOSE);
Table gDatos = new Table(shell,SWT.NONE);
TableColumn tcTelefono = new TableColumn(gDatos, SWT.NONE);
TableColumn tcNumero = new TableColumn(gDatos, SWT.NONE);
TableColumn tcExtencion = new TableColumn(gDatos, SWT.NONE);
tData = new GridData(GridData.FILL_BOTH);
GCustom gcustom = new GCustom(gDatos);
gDatos.setHeaderVisible(true);
gDatos.setLinesVisible(true);
tcTelefono.setText("Tipo");
tcNumero.setText("Numero");
tcExtencion.setText("Ext");
tData.horizontalIndent = 10;
gDatos.setLayoutData(tData);
tcTelefono.pack();
tcNumero.pack();
tcExtencion.pack();
/* control[0]=combo;
control[1]=boton;
control[2]=check; */
gcustom.setEditor(0,GCustom.COMBO);
gcustom.setEditor(1,GCustom.COMBO);
gcustom.setEditor(2,GCustom.BUTTON);
gcustom.setItem();
gcustom.setItem();
gcustom.setItem();
shell.setLayout(layout);
shell.setText(NAME);
shell.setSize(400,400);
shell.setImage(new Image(myDisplay,"image/so.gif"));
shell.open();
while (!shell.isDisposed())
if (!myDisplay.readAndDispatch())
myDisplay.sleep();
new prueba_tabla2();
Re: problem with the cell size [message #462080 is a reply to message #462078] Wed, 05 October 2005 16:49 Go to previous message
It's code by painting they widgets in table
package phantom.core;
import org.eclipse.swt.custom.TableEditor;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Combo;
import org.eclipse.swt.widgets.TableItem;
public class GCustom {
public static final int COMBO = 1;
public static final int BUTTON = 2;
public static final int CHECK = 3;
/* Widget[] control ;*/
int[] control;
String[] data;
Table gDatos;
//public void setEditor(int columna,Widget control)
public void setEditor(int columna,int control)
if ((columna >0 ) && (columna < gDatos.getColumnCount()))
this.control[columna] = control;
public void setItem()
TableItem item = new TableItem(gDatos,SWT.NONE);
TableEditor editor;
editor = new TableEditor (gDatos);
editor.minimumHeight = 50;
// editor.setItem();
for (int i = 0; i < control.length; i++) {
switch (control[i]) {
case BUTTON:
editor.horizontalAlignment = SWT.LEFT;
editor.grabHorizontal = true;
editor.grabVertical = true;
editor.minimumHeight = 20;
Button boton = new Button(gDatos,SWT.PUSH);
editor.setEditor (boton, item, i);
break;
case COMBO:
Combo combo = new Combo(gDatos, SWT.BORDER |
SWT.READ_ONLY);
combo.setSize(40,40);
editor.setEditor (combo, item, i);
break;
case CHECK:
editor = new TableEditor(gDatos);
// editor.
default:
break;
public GCustom(Table gDatos)
this.gDatos = gDatos;
control = new int[gDatos.getColumnCount()];
data = new String[gDatos.getColumnCount()];
//control = new Widget[gDatos.getColumnCount()];
static public void Custom()
Previous Topic:TableColumn hiding
Next Topic:label being cut off in wizard
Current Time: Sat Jul 19 09:44:52 EDT 2025
Powered by FUDForum. Page generated in 0.09477 seconds
