Home » Eclipse Projects » Rich Client Platform (RCP) » Viewer containing a JTable droppable
Viewer containing a JTable droppable [message #461645] Mon, 15 January 2007 06:56 Go to next message
I created a Viewer containing a javax.swing.JTable (using SWT_AWT).
I tried to add a drop support on this viewer, but with no result :/
In my viewer constructor, I did:
Control composite = new Composite(parent, SWT.NO_BACKGROUND
| SWT.EMBEDDED);
Frame frame = SWT_AWT.new_Frame((Composite) composite);
Panel panel = new Panel(new BorderLayout()) {
public void update(java.awt.Graphics g) {
paint(g);
frame.add(panel);
JRootPane root = new JRootPane();
panel.add(root);
java.awt.Container contentPane = root.getContentPane();
contentPane.add(component);
this.control = composite;
the method public Control getControl() returns this.control.
In the createPartControl of my viewerPart I did:
JTable table =...;
viewer = new TableViewer(parent, SWT.NONE, table);
int ops = DND.DROP_COPY | DND.DROP_MOVE;
Transfer[] transfers = new Transfer[] { LocalSelectionTransfer
getTransfer() };
viewer.addDropSupport(ops, transfers, new TableDropAdapater(viewer));
The dragEnter method of the DropAdapter is never called...
Am I doing something wrong?
Thanks Guilhaume
Re: Viewer containing a JTable droppable [message #461787 is a reply to message #461645] Wed, 17 January 2007 03:21 Go to previous messageGo to next message
Hi all,
Does somebody has any idea about that?
I am quite stuck with that
Guilhaume
Re: Viewer containing a JTable droppable [message #461974 is a reply to message #461787] Fri, 19 January 2007 08:25 Go to previous messageGo to next message
Hi all
This is an important issue for me, and I didn't find anything anywhere
about this.
Am I misunderstanding the way to achieve a drop on a JTable?
Guilhaume
Re: Viewer containing a JTable droppable [message #461982 is a reply to message #461645] Fri, 19 January 2007 10:30 Go to previous messageGo to next message
Pinard-Legry Guilhaume schrieb:
> | SWT.EMBEDDED);
> paint(g);
> frame.add(panel);
> panel.add(root);
> JTable table =...;
> getTransfer() };
Sorry but I can't follow you here where from do you have a table viewer
class with such a contructor. Is this a home grown viewer? Please post a
standalone snippet where we can reproduce the problem locally on our system.
Tom
Re: Viewer containing a JTable droppable [message #462026 is a reply to message #461982] Mon, 22 January 2007 04:28 Go to previous messageGo to next message
> Tom
of course: here you have:
--------// JTableViewer.java //---------------
package sample.jtable;
import java.awt.BorderLayout;
import java.awt.Frame;
import java.awt.Panel;
import java.util.List;
import javax.swing.JComponent;
import javax.swing.JRootPane;
import org.eclipse.jface.viewers.StructuredViewer;
import org.eclipse.swt.SWT;
import org.eclipse.swt.awt.SWT_AWT;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Control;
import org.eclipse.swt.widgets.Widget;
public class JTableViewer extends StructuredViewer {
private Control control;
public JTableViewer(Composite parent, int style, JComponent component) {
super();
| SWT.EMBEDDED);
private static final long serialVersionUID = -5327043823430217452L;
paint(g);
frame.add(panel);
panel.add(root);
public Control getControl() {
return control;
protected Widget doFindInputItem(Object element) {
return null;
protected Widget doFindItem(Object element) {
return null;
protected void doUpdateItem(Widget item, Object element, boolean fullMap)
protected List getSelectionFromWidget() {
return null;
protected void internalRefresh(Object element) {
public void reveal(Object element) {
protected void setSelectionToWidget(List l, boolean reveal) {
----------------// JTableViewPart.java //-------
import ilog.views.util.swt.IlvEventThreadUtil;
import javax.swing.JTable;
import org.eclipse.jface.util.LocalSelectionTransfer;
import org.eclipse.swt.dnd.DND;
import org.eclipse.swt.dnd.Transfer;
import org.eclipse.ui.part.ViewPart;
public class JTableViewPart extends ViewPart {
public static final String ID = JTableViewPart.class.getName();
private JTableViewer viewer;
static {
IlvEventThreadUtil.enableAWTThreadRedirect();
public void createPartControl(Composite parent) {
String[] columnNames = { "First Name", "Last Name", "Sport",
"# of Years", "Vegetarian" };
Object[][] data = {
{ "Mary", "Campione", "Snowboarding", new Integer(5),
new Boolean(false) },
{ "Alison", "Huml", "Rowing", new Integer(3), new Boolean(true) },
{ "Kathy", "Walrath", "Knitting", new Integer(2),
{ "Sharon", "Zakhour", "Speed reading", new Integer(20),
{ "Philip", "Milne", "Pool", new Integer(10),
new Boolean(false) } };
JTable table = new JTable(data, columnNames);
viewer = new JTableViewer(parent, SWT.NONE, table);
.getTransfer() };
viewer.addDropSupport(ops, transfers, new JTableDropAdapater(viewer));
public void setFocus() {
viewer.getControl().setFocus();
--------------// JTableDropAdapter.java //-----------
import org.eclipse.jface.viewers.Viewer;
import org.eclipse.jface.viewers.ViewerDropAdapter;
import org.eclipse.swt.dnd.DropTargetEvent;
import org.eclipse.swt.dnd.TransferData;
public class JTableDropAdapater extends ViewerDropAdapter {
protected JTableDropAdapater(Viewer viewer) {
super(viewer);
public boolean performDrop(Object data) {
return true;
public boolean validateDrop(Object target, int operation,
TransferData transferType) {
return true;
public void dragEnter(DropTargetEvent event) {
super.dragEnter(event);
System.out.println("ScheduleDropAdapater.dragEnter called");
public void dragLeave(DropTargetEvent event) {
super.dragLeave(event);
System.out.println("ScheduleDropAdapater.dragLeave called");
public void dragOver(DropTargetEvent event) {
super.dragOver(event);
System.out.println("ScheduleDropAdapater.dragOver called");
I hope this clarifies a bit my request.
Thanks for your efforts.
Guilhaume
Re: Viewer containing a JTable droppable [message #462304 is a reply to message #462026] Fri, 26 January 2007 03:51 Go to previous messageGo to next message
does the following code help understanding my request?
Thnaks
Guilhaume
> super();
> | SWT.EMBEDDED);
> paint(g);
> frame.add(panel);
> panel.add(root);
> return control;
> return null;
> return null;
> return null;
> static {
> Object[][] data = {
> .getTransfer() };
> super(viewer);
> return true;
> return true;
> Guilhaume
Re: Viewer containing a JTable droppable [message #462307 is a reply to message #462304] Fri, 26 January 2007 05:27 Go to previous messageGo to next message
I hope I can wrap my head around this problem on the weekend but I don't
think that I can be of big help the times I did Swing programming are a
long time ago. The only thing I can suggest to you is to use real
SWT-Controls and not Swing components.
I'm sure there's a reason that you are using Swing inside SWT but maybe
you should reajust your decision and use JFace-TableViewer which build
upon a real SWT-Table or if this widget set is not rich enough checkout
the controls from Nebula which will get JFace-Viewer support after M5 is
out.
Why are you using Swing?
Tom
> Thnaks
> Guilhaume
>> component) {
>> super();
>> | SWT.EMBEDDED);
>> paint(g);
>> frame.add(panel);
>> panel.add(root);
>> return control;
>> return null;
>> return null;
>> fullMap) {
>> return null;
>> static {
>> Object[][] data = {
>> Boolean(true) },
>> .getTransfer() };
>> super(viewer);
>> return true;
>> return true;
>> Guilhaume
Re: Viewer containing a JTable droppable [message #462313 is a reply to message #462307] Fri, 26 January 2007 10:09 Go to previous messageGo to next message
Hi Tom,
In fact I am using swing because I am developping an RCP application
including already-built swing components, and here, a schedule chart.
It is made of a Jtable and a Jcomponent, and I put this complex component
in a viewer (as I did in the sample for the single jtable).
When I hide the jtable of my schedule chart, the viewer becomes droppable.
If I show back the JTable, the viewer is not droppable anymore.
I shown it with the simple sample.
Thus I cannot replace the swing JTable with the JFace-TableViewer :(
IMHO it looks like a bug (but I'm not sure).
perhaps there a need to register a bug report (but I don't know how to do
that).
Thanks for the time you are spending on this issue.
Cheers
Guilhaume
Tom Schindl wrote:
> out.
> Tom
Re: Viewer containing a JTable droppable [message #462315 is a reply to message #462313] Fri, 26 January 2007 10:34 Go to previous message
You can also try to ask at the SWT-Newsgroup because this all sounds
like a bug in SWT and it's SWT_AWT-Bridge.
Fileing bugs isn't really a problem. Go to
https://bugs.eclipse.org/bugs/ and register an account, then file the
bug against Component SWT on
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Platform
One more thing I'm not sure I understand is why you wrap up your JTable
with a StructuredViewer what's the purpose of this, don't get me wrong
you can easily do all this but what's the profit of it. Swing-Components
are already MVC based and there's no need to but one more MVC-layer
above it.
Tom
> Hi Tom,
> component in a viewer (as I did in the sample for the single jtable).
> do that).
> Cheers
> Guilhaume
> Tom Schindl wrote:
>> Hi,
>> don't think that I can be of big help the times I did Swing
>> programming are a long time ago. The only thing I can suggest to you
>> is to use real SWT-Controls and not Swing components.
>> maybe you should reajust your decision and use JFace-TableViewer which
>> build upon a real SWT-Table or if this widget set is not rich enough
>> checkout the controls from Nebula which will get JFace-Viewer support
>> after M5 is out.
>> Tom
Previous Topic:[Jobs] JobErrorDialog does not appear in 3.3
Next Topic:Need help with product configuration
Current Time: Sun Jul 20 19:55:35 EDT 2025
Powered by FUDForum. Page generated in 0.04879 seconds
