Home » Eclipse Projects » Standard Widget Toolkit (SWT) » AWT.requestFocus deadlocks with SWT.EventQueue.invokeAndWait
AWT.requestFocus deadlocks with SWT.EventQueue.invokeAndWait [message #461465] Sat, 24 September 2005 10:08 Go to next message
The AWT event thread is blocked in WComponentPeer._requestFocus and the
SWT event thread is blocked in EventQueue.invokeAndWait - any idea what
the WComponentPeer is waiting for?
Thread [AWT-EventQueue-0] (Suspended)
WComponentPeer._requestFocus(Component, boolean, boolean, long)
line: not available [native method]
WEmbeddedFramePeer(WComponentPeer).requestFocus(Component,
boolean, boolean, long) line: not available
Report$LabelField(Component).requestFocusHelper(boolean,
boolean) line: not available
Report$LabelField(Component).requestFocus() line: not available
Report$LabelField(JComponent).requestFocus() line: not available
Report$LabelField.textChanged() line: 292
Report$LabelField.setText(String) line: 271
Report.setLabelText(Style, String) line: 449
LuminexReport.setLuminexFileName(String) line: 129
ReportView$1.run() line: 56
InvocationEvent.dispatch() line: not available
EventQueue.dispatchEvent(AWTEvent) line: not available
EventDispatchThread.pumpOneEventForHierarchy(int, Component)
line: not available
EventDispatchThread.pumpEventsForHierarchy(int, Conditional,
Component) line: not available
EventDispatchThread.pumpEvents(int, Conditional) line: not
available
EventDispatchThread.pumpEvents(Conditional) line: not available
EventDispatchThread.run() line: not available
Thread [TimerQueue] (Running)
Thread [main] (Suspended)
owns: RunnableLock (id=70)
waiting for: EventQueue$1AWTInvocationLock (id=69)
Object.wait(long) line: not available [native method]
EventQueue$1AWTInvocationLock(Object).wait() line: not available
EventQueue.invokeAndWait(Runnable) line: not available
LViewPart.invokeAndWait(Runnable) line: 161
DView.access$4(Runnable) line: 1
DView$MFolder.addDView(Composite, Assay, Marker) line: 279
DView$MFolder.createTabFolder(Composite) line: 264
DView$MFolder.<init>(DView, Assay, DView$MarkerName[],
Composite, int) line: 229
Composite) line: 219
DView.createPartControl(Composite) line: 107
ViewReference.createPartHelper() line: 305
ViewReference.createPart() line: 180
ViewReference(WorkbenchPartReference).getPart(boolean) line: 552
ViewPane(PartPane).setVisible(boolean) line: 283
ViewPane.setVisible(boolean) line: 512
PresentablePart.setVisible(boolean) line: 126
PresentablePartFolder.select(IPresentablePart) line: 268
LeftToRightTabOrder.select(IPresentablePart) line: 65
TabbedStackPresentation.selectPart(IPresentablePart) line: 391
ViewStack(PartStack).refreshPresentationSelection() line: 1102
ViewStack(PartStack).setSelection(LayoutPart) line: 1051
ViewStack(PartStack).showPart(LayoutPart, Object) line: 1256
ViewStack(PartStack).createControl(Composite,
StackPresentation) line: 576
ViewStack(PartStack).createControl(Composite) line: 528
ViewSashContainer(PartSashContainer).createControl(Composite )
line: 485
PerspectiveHelper.activate(Composite) line: 230
Perspective.onActivate() line: 813
WorkbenchPage.setPerspective(Perspective) line: 2928
WorkbenchPage.busySetPerspective(IPerspectiveDescriptor) line: 902
WorkbenchPage.access$11(WorkbenchPage, IPerspectiveDescriptor)
line: 887
WorkbenchPage$12.run() line: 3051
BusyIndicator.showWhile(Display, Runnable) line: 69
WorkbenchPage.setPerspective(IPerspectiveDescriptor) line: 3049
PlateEditor(LuminexEditorPart).switchPerspective(String) line: 294
PlateEditor.switchPerspective() line: 87
PlateEditor.access$3(PlateEditor) line: 84
PlateEditor$1.run() line: 103
RunnableLock.run() line: 35
UISynchronizer(Synchronizer).runAsyncMessages(boolean) line: 123
Display.runAsyncMessages(boolean) line: 3057
Display.readAndDispatch() line: 2716
Workbench.runEventLoop(Window$IExceptionHandler, Display) line:
1699
Workbench.runUI() line: 1663
Workbench.createAndRunWorkbench(Display, WorkbenchAdvisor)
line: 367
PlatformUI.createAndRunWorkbench(Display, WorkbenchAdvisor)
line: 143
Application.run(Object) line: 45
PlatformActivator$1.run(Object) line: 226
EclipseStarter.run(Object) line: 376
EclipseStarter.run(String[], Runnable) line: 163
NativeMethodAccessorImpl.invoke0(Method, Object, Object[])
NativeMethodAccessorImpl.invoke(Object, Object[]) line: not
available
DelegatingMethodAccessorImpl.invoke(Object, Object[]) line: not
available
Method.invoke(Object, Object...) line: not available
Main.invokeFramework(String[], URL[]) line: 334
Main.basicRun(String[]) line: 278
Main.run(String[]) line: 973
Main.main(String[]) line: 948
Re: AWT.requestFocus deadlocks with SWT.EventQueue.invokeAndWait [message #461485 is a reply to message #461465] Mon, 26 September 2005 09:57 Go to previous messageGo to next message
Probably request focus is trying to take focus from an SWT window, but
since you have the SWT thread waiting on the AWT event queue the SWT
thread can't process the request to release focus from the SWT window.
Rich Kulp
Re: AWT.requestFocus deadlocks with SWT.EventQueue.invokeAndWait [message #461604 is a reply to message #461485] Mon, 26 September 2005 22:33 Go to previous messageGo to next message
ok - is there a way to release swt focus before the invokeAndWait?
Re: AWT.requestFocus deadlocks with SWT.EventQueue.invokeAndWait [message #461681 is a reply to message #461485] Mon, 26 September 2005 22:34 Go to previous messageGo to next message
hmm - is there a way to release swt focus before the invokeAndWait?
Re: AWT.requestFocus deadlocks with SWT.EventQueue.invokeAndWait [message #461682 is a reply to message #461485] Mon, 26 September 2005 22:34 Go to previous messageGo to next message
Re: AWT.requestFocus deadlocks with SWT.EventQueue.invokeAndWait [message #461702 is a reply to message #461682] Tue, 27 September 2005 10:58 Go to previous messageGo to next message
No. You should probably do the invokeAndWait on a non-UI thread so that
the SWT UI thread stays responsive.
Rich Kulp
Re: AWT.requestFocus deadlocks with SWT.EventQueue.invokeAndWait [message #467614 is a reply to message #461702] Wed, 01 February 2006 16:43 Go to previous messageGo to next message
> David Scott wrote:
>>> but since you have the SWT thread waiting on the AWT event queue the
>>> SWT thread can't process the request to release focus from the SWT
>>> window.
Use invokeLater. requestFocus will call back into your SWT thread which
you just blocked by syncing with the AWT thread. invokeLater will
prevent your SWT from syncing (waiting) on your AWT thread. Ff you have
code that is dependant on focus received then use a focus listener as
callback. Late answer but others might want it.
-Sandi
Re: AWT.requestFocus deadlocks with SWT.EventQueue.invokeAndWait [message #467618 is a reply to message #467614] Wed, 01 February 2006 16:52 Go to previous message
That's true. That's why I said do the invokeAndWait on a NON-UI thread.
His code was doing an invokeAndWait so I assumed he needed to do a
series of steps in a certain order, one of which is the invokeAndWait.
But an invokeLater will work too if he doesn't need to wait or he does
the entire series of steps within the runnable passed to the invokeAndWait.
Sandi Schøllhammer wrote:
>> that the SWT UI thread stays responsive.
>>>> window.
> -Sandi
Rich Kulp
Previous Topic:Any simple example about inline text editing?
Next Topic:Text color of toolitem
Current Time: Sun Jul 20 06:12:18 EDT 2025
Powered by FUDForum. Page generated in 0.30622 seconds
