Home » Eclipse Projects » Rich Client Platform (RCP) » Classloader problems when bundling CGLIB as plugin
Classloader problems when bundling CGLIB as plugin [message #461312] Tue, 09 January 2007 04:46 Go to next message
Hi all,
Since our application needs to generate proxy classes at runtime I bundled
CGLIB as plugin. Hence our application consists of the following plugins :
1. Plugin A is CGLIB plugin.
2. Plugin B contains superclass of the new proxied classes.
3. Plugin C contains interfaces classes to be implemented by the proxy.
Here's what I put in the MANIFEST.MF of each plugin :
- Plugin A:
Eclipse-BuddyPolicy: registered
- Plugin B:
Require-Bundle: net.sf.cglib
- Plugin C:
Eclipse-RegisterBuddy: net.sf.cglib
This is the actual code that does the proxying :
Enhancer e = new Enhancer();
e.setSuperClass(superClass);
e.setInterfaces(new Class[]{interfaceClass});
e.setCallback(callback);
Object o = e.create();
At runtime the above code produces NoClassDefFoundError for unable to find
the interface class.
Then I tell CGLIB to use interface class classloader :
e.setClassLoader(interfaceClass.getClassLoader());
This produces NoClassDefFoundError for unable to find
net.sf.cglib.proxy.Factory class.
I also try to use context classloader :
e.setClassLoader(Thread.currentThread().getContextClassLoade r());
This time produces NoClassDefFoundError for unable to find the superclass.
In summary we need to resolve the following classes's classloader :
1. CGLIB.
2. Interface classes.
3. Superclass.
4. Proxied class.
What classloader should I use to resolve the above classes ?
Have anybody experienced the following problems ?
Any help would be greatly appreciated.
Best Regards,
Setya
Re: Classloader problems when bundling CGLIB as plugin [message #461342 is a reply to message #461312] Tue, 09 January 2007 09:57 Go to previous messageGo to next message
Setya wrote:
> Hi all,
> bundled CGLIB as plugin. Hence our application consists of the following
> plugins :
> - Plugin A:
> - Plugin B:
> - Plugin C:
Where is this code? Which plugin? And which plugin is it called from?
Later,
PW
Re: Classloader problems when bundling CGLIB as plugin [message #461372 is a reply to message #461342] Wed, 10 January 2007 04:15 Go to previous messageGo to next message
>> - Plugin A:
>> - Plugin B:
>> - Plugin C:
Sorry for the missing information, I also want to add minor correction.
1. The code resides in plugin B.
2. The code is called from plugin C.
2. Plugin B does not actually contain the superclass, but the superclass
resides in plugin D which is 'required' by plugin B.
So, in summary here's the correct architecture :
2. Plugin B contains contains code that generates new proxied class.
3. Plugin C contains interface classes to be implemented by the proxied
class.
4. Plugin D contains superclass.
Manifest.MF :
Plugin A:
Bundle-SymbolicName: net.sf.cglib
Plugin B:
Bundle-SymbolicName: plugin.b
Require-Bundle: net.sf.cglib, plugin.d
Plugin C:
Bundle-SymbolicName: plugin.c
Require-Bundle: plugin.b
Eclipse-RegisterBuddy: net.sf.cglib, plugin.b
Plugin D:
Bundle-SymbolicName: plugin.d
Export-Package: package.that.contains.superclass
Best Regards,
Setya
Re: Classloader problems when bundling CGLIB as plugin [message #461525 is a reply to message #461372] Thu, 11 January 2007 05:50 Go to previous messageGo to next message
> class.
> Manifest.MF :
> Plugin A:
> Plugin B:
> Plugin C:
> Plugin D:
Well, anybody has the same problem with cglib as plugin before ?
Setya
Re: Classloader problems when bundling CGLIB as plugin [message #461542 is a reply to message #461372] Thu, 11 January 2007 12:45 Go to previous messageGo to next message
Setya wrote:
> Plugin D:
How is plugin C supposed to be able to see the superclass? It looks
like its hidden behind plugin B (which can see it from plugin D).
I'm not sure which part is causing your problem, though.
Later,
PW
Re: Classloader problems when bundling CGLIB as plugin [message #462032 is a reply to message #461542] Mon, 22 January 2007 11:37 Go to previous message
Hi Setya,
Did you ever resolve this problem? Curious to know what you did. I was
playing with the buddy classloading system and was getting a
noclassdeffound error as well.
Have you tried simply accessing a dummy static method from Plugin D in
your Plugin B code? Are you able to see any classes at runtime from
Plugin D (accessed from plugin B)?
- Nik
Paul Webster wrote:
> Setya wrote:
>> Plugin D:
> Later,
> PW
Previous Topic:PreferenceConverter throws Exception
Next Topic:XML Editor problem
Current Time: Sun Jul 20 15:10:58 EDT 2025
Powered by FUDForum. Page generated in 0.04968 seconds
