Home » Eclipse Projects » Rich Client Platform (RCP) » Problem opening a file in the RCP application
Problem opening a file in the RCP application [message #460685] Thu, 28 December 2006 05:19 Go to next message
I tried to open a file by adding my own action, SampleAction to a toolbar. I
used the OpenExternalFileAction.java
( http://www.koders.com/java/fid513463C78735A056B09498429C20BA FB6B4307AF.aspx)code.
This is the same code that Eclipse uses to perform the same action of
opening a file. When I run the application the SampleAction code seems to
stop running at
IFileStore fileStore= EFS.getLocalFileSystem().getStore(new
Path(fFilterPath));
Need any solution regarding this issue.
Thanks in advance!!
Krishna
Re: Problem opening a file in the RCP application [message #460702 is a reply to message #460685] Thu, 28 December 2006 11:07 Go to previous messageGo to next message
Hi Krishna,
If your code does not throw an Exception, is there a message in the
Eclipse log file?
Are you including org.eclipse.core.filesystem (and its counter-part for
your operating system) with your application?
Charlie
> stop running at
> Path(fFilterPath));
> Thanks in advance!!
> Regards,
> Krishna
Re: Problem opening a file in the RCP application [message #460704 is a reply to message #460702] Thu, 28 December 2006 12:30 Go to previous messageGo to next message
Thanks Charle!!
I tried including the following jars and runing the application.
1. org.eclipse.core.filesystem.win32.x86_1.0.0.v20060603.jar
2. org.eclipse.core.filesystem_1.0.0.v20060603.jar
But it still gives me the following error in the log file.
!SESSION 2006-12-28
22:52:35.855 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.5.0_08
Framework arguments: -application
com.cisco.nm.cmp.client.ui.workbench.app -pdelaunch
Command-line arguments: -application
com.cisco.nm.cmp.client.ui.workbench.app -data C:\Eclipse Workspaces\View
try out/../runtime-EclipseApplication -dev file:C:/Eclipse Workspaces/View
try out/.metadata/.plugins/org.eclipse.pde.core/Application with Config
Archive/dev.properties -pdelaunch -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.ui 4 4 2006-12-28 22:52:40.621
!MESSAGE Invalid Menu Extension (Path is invalid):
convertToWebModuleTypeAction
!ENTRY org.eclipse.ui 4 4 2006-12-28 22:52:40.668
org.eclipse.ui.edit.text.gotoLastEditPosition
!ENTRY org.eclipse.ui 4 4 2006-12-28 22:52:40.933
org.jboss.ide.eclipse.packaging.ui.actions.PackagingRunActio n
!ENTRY org.eclipse.ui 4 4 2006-12-28 22:52:41.136
org.jboss.ide.eclipse.xdoclet.run.ui.actions.XDocletRunActio n
!ENTRY org.eclipse.osgi 2 1 2006-12-28 22:52:42.183
!MESSAGE NLS missing message: EventLogCategory in:
org.jboss.ide.eclipse.as.ui.Messages
!MESSAGE NLS missing message: HidePropertiesAction in:
!MESSAGE NLS missing message: HideTextAction in:
!MESSAGE NLS missing message: HideLowerFrameAction in:
!ENTRY org.eclipse.ui 4 4 2006-12-28 22:52:55.027
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 2006-12-28 22:52:55.027
!MESSAGE org/eclipse/core/filesystem/EFS
!STACK 0
java.lang.NoClassDefFoundError: org/eclipse/core/filesystem/EFS
at
com.cisco.nm.cmp.ems.ems_configarchive_gui.actions.SampleAct ion.run(SampleAction.java:326)
at
com.cisco.nm.cmp.ems.ems_configarchive_gui.actions.SampleAct ion.run(SampleAction.java:299)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:254)
at
org.eclipse.ui.internal.WWinPluginAction.runWithEvent(WWinPl uginAction.java:229)
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:539)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
at
org.eclipse.jface.action.ActionContributionItem$6.handleEven t(ActionContributionItem.java:441)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3348)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2968)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at
com.cisco.nm.cmp.client.ui.workbench.rcp.CMPApplication.run( CMPApplication.java:49)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Thanks in advance!!
Krishna
"Charle Kelly" <Eclipse@CharlieKelly.com> wrote in message
news:en0q3t$2iq$1@utils.eclipse.org...
> Hi Krishna,
> Eclipse log file?
> Charlie
>> toolbar. I used the OpenExternalFileAction.java
>> stop running at
>> Path(fFilterPath));
>> Thanks in advance!!
>> Regards,
>> Krishna
Re: Problem opening a file in the RCP application [message #460705 is a reply to message #460704] Thu, 28 December 2006 13:02 Go to previous messageGo to next message
Hi Krishna,
Are you using JBossIDE version 1.6 or 2.0 (1.6 uses Eclipse 3.1 libraries).
You might try inserting Class.forName (...) for
in the SampleAction.run() method.
This would distinguish between a ClassDef error and a "path" error.
Charlie
krishna wrote:
> Thanks Charle!!
> !SESSION 2006-12-28
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks in advance!!
> Regards,
> Krishna
>>Hi Krishna,
>>Eclipse log file?
>>Charlie
>>>stop running at
>>>Path(fFilterPath));
>>>Thanks in advance!!
>>>Regards,
>>>Krishna
Re: Problem opening a file in the RCP application [message #460715 is a reply to message #460704] Thu, 28 December 2006 17:59 Go to previous messageGo to next message
And, of course, you have also included org.eclipse.core.runtime, upon which some of these things depend?
Alex.
Re: Problem opening a file in the RCP application [message #460770 is a reply to message #460715] Fri, 29 December 2006 01:07 Go to previous messageGo to next message
Hi Alex,
Yes I have included org.eclipse.core.runtime .
Krishna
Re: Problem opening a file in the RCP application [message #460772 is a reply to message #460705] Fri, 29 December 2006 01:20 Go to previous messageGo to next message
Hi Charle,
Thanks for replying!!
I am using JBoss IDE Version 2.0 (Build Id 2.0.0.Beta2)
I tried using Class.forName().
Class efs = null;
try {
efs = Class.forName("EFS");
} catch (ClassNotFoundException e) {
e.printStackTrace();
try {
ifile = (IFile)((EFS)
efs.newInstance()).getLocalFileSystem().getStore(new Path(path));
} catch (InstantiationException e) {
} catch (IllegalAccessException e) {
When I try to run the app now it gives me an chosen operation not
currently available dialog. The following exception is thrown in the log
file.
!ENTRY org.eclipse.ui 4 4 2006-12-29 11:19:02.125
!MESSAGE Internal plug-in action delegate error on creation.
!STACK 0
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Unknown Source)
at java.lang.Class.getConstructor0(Unknown Source)
at java.lang.Class.newInstance0(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
at
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:157)
at
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:759)
at
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
at
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi n.java:242)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
at
org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java:238)
at
org.eclipse.ui.internal.PluginAction.createDelegate(PluginAc tion.java:120)
at
org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:225)
at
at
at
at
at
at
at
at
at
at
at
Thanks in advance!!
Krishna
Re: Problem opening a file in the RCP application [message #460819 is a reply to message #460704] Fri, 29 December 2006 14:10 Go to previous message
Originally posted by: krishna.kamath.gmail.com
I had added the required files in my build path rather than in
dependencies.
I am now able to solve the problem.
Thanks Charle and Alex... :)
Krishna
Previous Topic:Activator stop(): call super first or last?
Next Topic:MessageConsole NoClassDefFoundError
Current Time: Sat Jul 19 20:56:59 EDT 2025
Powered by FUDForum. Page generated in 0.05491 seconds
