Home » Eclipse Projects » Rich Client Platform (RCP) » ContentAssist: additional Info
ContentAssist: additional Info [message #460253] |
Mon, 18 December 2006 10:10  |
Originally posted by: febro.gmx.net
I'm working an ContentAssistance and the main part - showing the proposals -
works good, but now I want to show additional information about the selected
element - like in the standar java editor, when you select an element in the
proposal list, a second popup with the corresponding "javadoc" is shown...
how to do this?
i already tried the code below, but it doens't work (the proposal list is
shown correctly, but no additional infos). Any hints?
thx!
Felix
ContextInformation ci = new ContextInformation("1", "2");
completion.add(new CompletionProposal(text, currentText.documentOffset,
currentText.text.length(), text.length(), null, name, ci,
element.getDescription()));
Re: ContentAssist: additional Info [message #460315 is a reply to message #460253] |
Tue, 19 December 2006 08:43   |
Felix brossmann wrote:
>Hi,
>how to do this?
See ICompletionProposal.getAdditionalProposalInfo()
Dani
>thx!
>Felix
Re: ContentAssist: additional Info [message #460332 is a reply to message #460315] |
Wed, 20 December 2006 02:56   |
> >proposals -
> >selected
> >the
> >shown...
> >how to do this?
Thanks, but that doesn't help... I use this constructor:
currentText.text.length(), text.length(), null, name, null,
The last parameter sets the description.
How can I *show* the description? Do I have to code this manually?
I use a
public class TagContentAssistProcessor implements
IContentAssistProcessor
In the method "public ICompletionProposal[]
computeCompletionProposals(ITextViewer viewer, int offset)", an array is
built (using the constructor I wrote earlier) and returned. That's what
I do. The proposal-list is shown, but not the additional information...
This is a snippet from my "getContentAssistant"-method... Do I have to
set some flags here? I haven't found anything interesting in
"ContentAssistant", so I don't think so...
ContentAssistant assistant = new ContentAssistant();
assistant.setContentAssistProcessor(new
TagContentAssistProcessor(getXMLTagScanner()),
XMLPartitionScanner.XML_TAG);
assistant.enableAutoActivation(true);
assistant.setAutoActivationDelay(500);
assistant.setProposalPopupOrientation(IContentAssistant.CONT EXT_INFO_BEL
OW);
assistant.setContextInformationPopupOrientation(IContentAssi stant.CONTEX
T_INFO_ABOVE);
return assistant;
Felix
Re: ContentAssist: additional Info [message #460339 is a reply to message #460332] |
Wed, 20 December 2006 07:14   |
>>>proposals -
>>>selected
>>>the
>>>shown...
>>>how to do this?
No, the additional info should appear automatically after a short
time-out. If that doesn't work for you simply file a bug report against
Platform Text with steps (best is your code - at least the one that does
code assist).
Dani
>I use a
>OW);
>T_INFO_ABOVE);
> return assistant;
>Felix
Re: ContentAssist: additional Info [message #461760 is a reply to message #460339] |
Tue, 16 January 2007 08:42  |
ok I got it:
the following line had to be added:
assistant.setInformationControlCreator(getInformationControl Creator(sourceViewer));
"Daniel Megert" <daniel_megert@ch.ibm.com> schrieb im Newsbeitrag
news:emb9fd$m6r$1@utils.eclipse.org...
>>>>proposals -
>>>>selected
>>>>the
>>>>shown...
>>>>how to do this?
>>>>is
> code assist).
> Dani
>>I use a
>>OW);
>>T_INFO_ABOVE);
>> return assistant;
>>Felix
Current Time: Sat Jul 19 12:24:46 EDT 2025
Powered by FUDForum. Page generated in 0.05028 seconds
