Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Table layout on Linux/GTK
Table layout on Linux/GTK [message #460069] Sun, 21 August 2005 20:31 Go to next message
For the purposes of my application I'm implementing a mechanism that
persists selected table column widths across platform restarts. For this
purpose I wrote a custom table layout manager (I couldn't use the supplied
TableLayout for reasons not relevant to this problem) and I have a control
listener on each table column that saves the new width whenever a column is
resized by the user. That saved width is then used by my layout manager to
size the columns whenever it is asked to layout the table. The problem is
this works fine on win32, but when running on Linux/GTK some internal
mechanism sets column sizes initially to some default values, looks like it
is 10 pixels for each column, and the last column is made to occupy the rest
of the available space on the right. This happens even if no layout manager
was set and prior to layout() is called on the manager if it is set. As a
result I'm stuck with these values as my layout manager will use them when
its layout() method is called.
When run, the following snippet will print nothing on win32 but will print 2
resize and 1 move event on GTK. Any Ideas?
Vladimir.
Display display = new Display ();
Shell shell = new Shell (display);
shell.setSize (200, 200);
shell.setLayout(new FillLayout());
shell.open ();
Table table = new Table (shell, SWT.BORDER | SWT.V_SCROLL | SWT.H_SCROLL);
table.setLinesVisible(true);
table.setHeaderVisible(true);
TableColumn col1 = new TableColumn(table, SWT.NONE);
col1.setResizable(true);
col1.setText("col1");
TableColumn col2 = new TableColumn(table, SWT.NONE);
col2.setResizable(true);
col2.setText("col2");
ControlListener listener = new ControlListener() {
public void controlMoved(ControlEvent e) {
System.out.println("moved");
public void controlResized(ControlEvent e) {
System.out.println("resized " + ((TableColumn)e.widget).getWidth());
col1.addControlListener(listener);
col2.addControlListener(listener);
for (int i=0; i<12; i++) {
TableItem item = new TableItem (table, 0);
item.setText (0, "Item " + i);
item.setText (1, "Item_ " + i);
shell.layout();
while (!shell.isDisposed()) {
if (!display.readAndDispatch ()) display.sleep ();
display.dispose ();
Re: Table layout on Linux/GTK [message #460074 is a reply to message #460069] Sun, 21 August 2005 21:28 Go to previous messageGo to next message
Seems that the workaround for this problem is to set the column width
initially to the value would
be set by the layout manager in its layout() method. This will still
generate the initial resize
events but the new width will be what was explicitly set instead of the
default length values
(coming from GTK???).
"Vladimir Grishchenko" <vgrishchenko@serena.com> wrote in message
news:deb6b4$9m3$1@news.eclipse.org...
is
it
rest
manager
2
> Vladimir.
> shell.open ();
> shell.layout();
> display.dispose ();
Re: Table layout on Linux/GTK [message #460250 is a reply to message #460069] Tue, 23 August 2005 09:40 Go to previous messageGo to next message
Please post a bug to bugs.eclipse.org/bugs/ against Platform > SWT
along with the code snippet.
-Billy
Re: Table layout on Linux/GTK [message #460289 is a reply to message #460250] Tue, 23 August 2005 13:45 Go to previous message
see: https://bugs.eclipse.org/bugs/show_bug.cgi?id=107758
"Billy Biggs" <bbiggs@ca.ibm.com> wrote in message
news:def914$7k7$2@news.eclipse.org...
print 2
> -Billy
Previous Topic:Problems with Table and tableViewer
Next Topic:Firefox browser on Linux
Current Time: Sat Jul 19 10:43:06 EDT 2025
Powered by FUDForum. Page generated in 0.06363 seconds
