Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Does Table support SWT.MouseDoubleClick events?
Does Table support SWT.MouseDoubleClick events? [message #460215] Mon, 22 August 2005 17:08 Go to next message
I can't seem to get Table to handle SWT.MouseDoubleClick events.
Does Table support these events?
Andy Arhelger
Re: Does Table support SWT.MouseDoubleClick events? [message #460223 is a reply to message #460215] Mon, 22 August 2005 18:52 Go to previous messageGo to next message
> Andy Arhelger
Is there any reason you can't use a selection listener ->
widgetDefaultSelected()?
Re: Does Table support SWT.MouseDoubleClick events? [message #460256 is a reply to message #460223] Tue, 23 August 2005 09:54 Go to previous messageGo to next message
widgetDefaultSelected seems to get called when Enter is pressed not when
the mouse is doubleclicked. I am trying to create a cell editor on
double click. I would like single click to just select the row in the
table and double click to edit the table cell.
Andy Arhelger
>> Andy Arhelger
Re: Does Table support SWT.MouseDoubleClick events? [message #460265 is a reply to message #460256] Tue, 23 August 2005 10:32 Go to previous messageGo to next message
Listening for DefaultSelection should notify you for both Enter presses and
for double clicks. Do you have a case where this is not happening? If so,
which platform are you on, and can you post a stand-alone snippet that shows
the problem?
Grant
"Andy Arhelger" <juggle@us.ibm.com> wrote in message
news:def9re$8vr$1@news.eclipse.org...
> Andy Arhelger
> >> Andy Arhelger
Re: Does Table support SWT.MouseDoubleClick events? [message #460269 is a reply to message #460265] Tue, 23 August 2005 11:06 Go to previous messageGo to next message
On Windows, SWT 3.1. Tried again. Enter works but not double click. I
can try to create a stand-alone.
Andy Arhelger
> the problem?
> Grant
>>Andy Arhelger
>>>>Andy Arhelger
Re: Does Table support SWT.MouseDoubleClick events? [message #460278 is a reply to message #460269] Tue, 23 August 2005 12:10 Go to previous messageGo to next message
Andy,
I'm going to guess that you have a Table without FULL_SELECTION and are
trying to double-click in a non-0 column (?). If so, then selecting a cell
that's not in column 0 requires that the Table be created with
SWT.FULL_SELECTION. The snippet below demonstrates this.
If my guess was wrong then you can still try the snippet below (it fires
default selection for me), and if it works for you too then just modify it
to make it fail.
Display display = new Display ();
Shell shell = new Shell (display);
shell.setBounds (10,10,200,200);
Table table = new Table (shell, SWT.FULL_SELECTION);
table.setBounds (10,10,150,100);
new TableColumn(table, SWT.NONE).setWidth(75);
new TableItem(table, SWT.NONE).setText(new String[] {"item c0","item
c1"});
table.addListener(SWT.DefaultSelection, new Listener() {
public void handleEvent(Event e) {
System.out.println("default selection: " + e.toString());
shell.open ();
while (!shell.isDisposed ()){
if (!display.readAndDispatch ()) display.sleep ();
display.dispose ();
Grant
news:defe22$fjf$1@news.eclipse.org...
> Andy Arhelger
and
so,
shows
> > the problem?
> > Grant
> >>Andy Arhelger
> >>>>Andy Arhelger
Re: Does Table support SWT.MouseDoubleClick events? [message #460290 is a reply to message #460278] Tue, 23 August 2005 13:46 Go to previous messageGo to next message
I do have FULL_SELECTION set. But I also have a TableCursor. TableCursor
seems to be preventing the default selection event.
Andy Arhelger
Grant Gayed wrote:
> Andy,
> to make it fail.
> public static void main(String[] args) {
> c1"});
> shell.open ();
> display.dispose ();
> Grant
>>Andy Arhelger
> and
> so,
> shows
>>>the problem?
>>>Grant
>>>>Andy Arhelger
>>>>>>Andy Arhelger
Re: Does Table support SWT.MouseDoubleClick events? [message #460305 is a reply to message #460256] Tue, 23 August 2005 20:14 Go to previous messageGo to next message
> Andy Arhelger
Could you post a snippet?
Using a mouse listener on a table should give you the ability to capture
double clicks anywhere on the table. Using a selection listener should
give the ability to capture table selections with single (widgetSelected)
and/or double clicks (widgetDefaultSelected). So I'm not sure why its not
working in your case, but a snippet would be useful.
Chris.
Re: Does Table support SWT.MouseDoubleClick events? [message #460307 is a reply to message #460290] Tue, 23 August 2005 20:19 Go to previous messageGo to next message
> Andy Arhelger
Andy,
have you tried adding a selectionListener to the TableCursor itself,
rather than the Table? (using widgetDefaultSelected() )
Re: Does Table support SWT.MouseDoubleClick events? [message #460404 is a reply to message #460307] Wed, 24 August 2005 14:25 Go to previous message
Chris:
Thanks, that did the trick!
Andy Arhelger
>> TableCursor seems to be preventing the default selection event.
>> Andy Arhelger
> Andy,
Previous Topic:Sections of a perspective
Next Topic:swt browser on pocket pc
Current Time: Sat Jul 19 05:47:15 EDT 2025
Powered by FUDForum. Page generated in 0.23987 seconds
