Error org.eclipse.swt.SWTException: Class ID not found in registry result [message #460243] |
Tue, 23 August 2005 05:23 |
Originally posted by: sendtanmoy.yahoo.co.in
i am trying to open a pdf document inside a view of an RCP application.
when i run the application i get the follwoing error.
org.eclipse.swt.SWTException: Class ID not found in registry result = -2147221005
at org.eclipse.swt.ole.win32.OLE.error(OLE.java:317)
at org.eclipse.swt.ole.win32.OleClientSite.getClassID(OleClient Site.java:652)
at org.eclipse.swt.ole.win32.OleControlSite.<init>(OleControlSite.java:88)
at rCPDemo.AcrobatReader.render(AcrobatReader.java:62)
at rCPDemo.PDFView.createPartControl(PDFView.java:48)
at org.eclipse.ui.internal.ViewReference.createPartHelper(ViewR eference.java:305)
at org.eclipse.ui.internal.ViewReference.createPart(ViewReferen ce.java:180)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:552)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:28 3)
at org.eclipse.ui.internal.ViewPane.setVisible(ViewPane.java:51 2)
at org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:126)
at org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(PresentablePartFolder.java:268)
at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftToRightTabOrder.java:65)
at org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(TabbedStackPresentation.java:391)
at org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1102)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:1051)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:12 56)
at org.eclipse.ui.internal.PartStack.createControl(PartStack.ja va:576)
at org.eclipse.ui.internal.PartStack.createControl(PartStack.ja va:528)
at org.eclipse.ui.internal.PartSashContainer.createControl(Part SashContainer.java:485)
at org.eclipse.ui.internal.PerspectiveHelper.activate(Perspecti veHelper.java:230)
at org.eclipse.ui.internal.Perspective.onActivate(Perspective.j ava:813)
at org.eclipse.ui.internal.WorkbenchPage.onActivate(WorkbenchPa ge.java:2165)
at org.eclipse.ui.internal.WorkbenchWindow$5.run(WorkbenchWindo w.java:2356)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at org.eclipse.ui.internal.WorkbenchWindow.setActivePage(Workbe nchWindow.java:2338)
at org.eclipse.ui.internal.WorkbenchWindow.busyOpenPage(Workben chWindow.java:681)
at org.eclipse.ui.internal.Workbench.busyOpenWorkbenchWindow(Wo rkbench.java:669)
at org.eclipse.ui.internal.Workbench.doOpenFirstTimeWindow(Work bench.java:1282)
at org.eclipse.ui.internal.Workbench.openFirstTimeWindow(Workbe nch.java:1223)
at org.eclipse.ui.internal.WorkbenchConfigurer.openFirstTimeWin dow(WorkbenchConfigurer.java:190)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:706)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1034)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1636)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at rCPDemo.Application.run(Application.java:18)
at org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
how to get rid of this error.
FUDForum. Page generated in 0.07035 seconds
