Home » Eclipse Projects » Rich Client Platform (RCP) » Using update manager to update plugins in commercial applications
Using update manager to update plugins in commercial applications [message #460150] Fri, 15 December 2006 05:27 Go to next message
Originally posted by: vishal.zadoo.ottogroup.com
We are building a commercial application using eclipse rcp and need a way to update the plugins. I read about the Update Manager, but it seems u need to manually run it from a menu option provided in the eclipse IDE. However the user shall not have the eclipse IDE installed on his desktop. He shall only have the product that we deliver. How do I enable an update manager in that case?
Also i would like a facility to automatically detect updates and install them . Is that possible?
Thanks for your help in advance.
Vishal
Re: Using update manager to update plugins in commercial applications [message #460154 is a reply to message #460150] Fri, 15 December 2006 07:58 Go to previous messageGo to next message
Originally posted by: tom.seidel.spiritlink.de
veezee schrieb:
> Vishal
The Update-Manager has nothing to do with the Eclipse IDE. You have to
set dependencies to org.eclipse.update.*. Provide in your product a
button, menu or something else, where the update-manager is called. It
searches for updates to installed features on update-sites you have
assigned in the feature.
In your IDE-Preferences you have the preference page
Install/Update-->Automatic Update. Theses preferences will be aviable if
you integrate the update-manager in your product.
Cheerz,
Tom
Re: Using update manager to update plugins in commercial applications [message #460218 is a reply to message #460154] Mon, 18 December 2006 04:32 Go to previous messageGo to next message
Hi Tom,
Thanks for the valuable info. One doubt however. After including dependencies as org.eclipse.update.*, u said that I shud call teh update-manager on click of some button. How do i do that? is there any api or sumthin available for that?
Thanks for the help .
Vishal
Re: Using update manager to update plugins in commercial applications [message #460220 is a reply to message #460218] Mon, 18 December 2006 05:02 Go to previous messageGo to next message
veezee schrieb:
> Hi Tom,
> Vishal
see org.eclipse.ui.internal.ide.update.InstallWizardAction
Cheerz,
Tom
Re: Using update manager to update plugins in commercial applications [message #460230 is a reply to message #460154] Mon, 18 December 2006 07:23 Go to previous message
thanks a lot Tom.
it works now. I did not add the dependency earlier, but was adding the update plugins as the required plugins only.
works now!!!
Previous Topic:listening to preference changes
Next Topic:Adding IWorkbenchWindowActionDelegate action in context menu
Current Time: Sat Jul 19 16:23:11 EDT 2025
Powered by FUDForum. Page generated in 0.27519 seconds
