Home » Eclipse Projects » Rich Client Platform (RCP) » Switch workspace question
Switch workspace question [message #460127] Thu, 14 December 2006 09:08 Go to next message
Originally posted by: janky.hot.ee
i'm trying to implement the switch workspace action. So my question is
how and when i could change to directory i get with
Platform.getInstanceLocation()?
I don't want to add the org.eclipse.ui.ide library to my applicatin.
I'd be very appreciated if someone could guide or link me to right place.
Re: Switch workspace question [message #460128 is a reply to message #460127] Thu, 14 December 2006 09:38 Go to previous messageGo to next message
VJ wrote:
Workspace location can be either set in your Application.run() method, by
calling Platform.getInstanceLocation().setURL(), or by restarting Eclipse
instance with substituted command line arguments, like they do in
OpenWorkspaceAction
( http://www.koders.com/java/fid5F6054C787BB6E91B1813280EC757F 57AB0E6613.aspx).
With best regards, Michael Spector
Re: Switch workspace question [message #460130 is a reply to message #460128] Thu, 14 December 2006 09:48 Go to previous messageGo to next message
If i do the the first example then i get an exception
java.lang.IllegalStateException: Cannot change the location once it is
set. So the following code is not OK, or it's not possible to do this way???
public Object run(Object args) throws Exception {
URL newLoc = new File("H:/newworkspace/").toURL();
Platform.getInstanceLocation().setURL(newLoc, false);
Display display = PlatformUI.createDisplay();
try {
int returnCode = PlatformUI.createAndRunWorkbench(display, new
ApplicationWorkbenchAdvisor());
if (returnCode == PlatformUI.RETURN_RESTART) {
return IPlatformRunnable.EXIT_RESTART;
return IPlatformRunnable.EXIT_OK;
} finally {
display.dispose();
Michael Spector wrote:
> VJ wrote:
>> Hi,
> OpenWorkspaceAction
Re: Switch workspace question [message #460131 is a reply to message #460127] Thu, 14 December 2006 09:51 Go to previous messageGo to next message
VJ wrote:
When: It must be done, *before* PlatformUI.createAndRunWorkbench has
been called, so the latest point is inside your IPlatformRunnable.run
implementation just before you call PlatformUI.createAndRunWorkbench.
How: Have a look at org\eclipse\ui\internal\ide\IDEApplication.java
from the org.eclipse.ui.ide plugin.
Basically you need a sequence similar to:
File fUserWorkspace = ... // your workspace
final Location instanceLoc = Platform.getInstanceLocation();
if (instanceLoc == null) {
.. //error
// Note: Don't use File.toURL()!
String path = fUserWorkspace.getAbsolutePath().replace(
File.separatorChar, '/');
URL userWSURL = new URL("file", null, path);
if (instanceLoc.isSet()) {
if (!userWSURL.sameFile(instanceLoc.getURL())) {
... // error
} else {
if (!fUserWorkspace.exists()) {
if (!fUserWorkspace.mkdirs()) {
... // error
// You can use another locking policy as well:
final boolean doLock = false;
if (!instanceLoc.setURL(userWSURL, doLock) == doLock) {
... // error
Greetings from Bremen,
Daniel Krügler
Re: Switch workspace question [message #460133 is a reply to message #460130] Thu, 14 December 2006 09:58 Go to previous messageGo to next message
> way???
Have a look at the IDEApplication class, you'll find how they do it exactly.
Re: Switch workspace question [message #460148 is a reply to message #460133] Fri, 15 December 2006 02:55 Go to previous message
>> way???
thx all of you, classes IDEApplication and OpenWorkspaceAction were
quite useful to study.
Previous Topic:How to use OleFrame within a ScrolledComposite?
Next Topic:java.lang.NullPointer
Current Time: Sun Jul 20 14:10:24 EDT 2025
Powered by FUDForum. Page generated in 0.11612 seconds
