Home » Eclipse Projects » Rich Client Platform (RCP) » how to configure Application Title at runtime?
how to configure Application Title at runtime? [message #460036] Tue, 12 December 2006 03:14 Go to next message
as we all know, the title is configured by using
IWorkbenchWindowConfigurer.setTitle(String title)
but at runtime, how shall we get IWorkbenchWindowConfigurer to reset the
title?
Chandler
Re: how to configure Application Title at runtime? [message #460040 is a reply to message #460036] Tue, 12 December 2006 04:21 Go to previous messageGo to next message
> title?
I've used the following technique:
public static void changeAppTitle(String newTitle) {
Display display = Display.getDefault();
if (display != null) {
// Look at all the shells and pick the first one
// that is a workbench window.
Shell shells[] = display.getShells();
for (int i = 0; i < shells.length; i++) {
Object data = shells[i].getData();
// Check whether this shell points to the Application main window's
shell:
if (data instanceof IWorkbenchWindow) {
shells[i].setText(newTitle);
break;
With best regards, Michael Spector
Re: how to configure Application Title at runtime? [message #460048 is a reply to message #460040] Tue, 12 December 2006 09:25 Go to previous messageGo to next message
I've used a different method, that I *think* is safer, but requires setting up a suitable
listener-mechanism to respond to whatever it is that you want to have determine the new title; in my
case, it's a preference. I do it all in the WorkbenchWindowAdvisor, note calls to setTitle() in two
places:
MyWorkbenchWindowAdvisor extends WorkbenchWindowAdvisor implements IPropertyChangeListener {
public void preWindowOpen() {
super.preWindowOpen();
_configurer = getWindowConfigurer();
<other code>
setTitle();
PreferencesImpl.store().addPropertyChangeListener(this);
public void propertyChange(final PropertyChangeEvent event) {
if (event.getProperty().equals(MY_PREFERENCE_KEY)) {
if (!event.getOldValue().equals(event.getNewValue())) {
setTitle();
protected void setTitle() {
final String title = computeNewTitleHoweverYouLike();
_configurer.setTitle(title);
protected IWorkbenchWindowConfigurer _configurer;
HTH,
Paul
Re: how to configure Application Title at runtime? [message #460075 is a reply to message #460040] Wed, 13 December 2006 01:36 Go to previous message
Thanks a lot, I got the solution now:
I pass a WorkbenchWindow parameter into Action constructor when create
the instance in ActionBarAdvisor.
Then in the action, we can use window.getShell().setText()....
> shell:
> break;
Previous Topic:Automatic Updates and New Features
Next Topic:Add javadoc for context help to a plugin
Current Time: Sat Jul 19 14:19:21 EDT 2025
Powered by FUDForum. Page generated in 0.08935 seconds
