ScrolledComposite and StackLayout [message #459412] |
Tue, 09 August 2005 04:47  |
I have a problem with a ScrolledComposite containing a Composite with a
StackLayout layout.
The code provided below shows the problem:
The vertical scroll bar is sized for the tallest composite within the
stack, even if a smaller one is on top.
Is this normal or should I create a ScrolledComposite for each Composite
on the stack ?
import org.eclipse.swt.SWT;
import org.eclipse.swt.custom.ScrolledComposite;
import org.eclipse.swt.custom.StackLayout;
import org.eclipse.swt.events.SelectionAdapter;
import org.eclipse.swt.events.SelectionEvent;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.Text;
public class ScrollAndStack {
private static Shell shell;
private static int currentCompositeNumber = 0;
private static Composite0 composite0;
private static Composite1 composite1;
private static Composite stack;
private static ScrolledComposite scroll;
public ScrollAndStack() {
scroll = new ScrolledComposite(shell, SWT.H_SCROLL | SWT.V_SCROLL);
scroll.setExpandHorizontal(true);
scroll.setExpandVertical(true);
stack = new Composite(scroll, SWT.BORDER);
stack.setLayout(new StackLayout());
composite0 = new Composite0(stack, SWT.BORDER);
composite1 = new Composite1(stack, SWT.BORDER);
StackLayout layout = (StackLayout)stack.getLayout();
layout.topControl = composite0;
scroll.setContent(stack);
scroll.setMinSize(stack.computeSize(SWT.DEFAULT, SWT.DEFAULT));
stack.layout();
Display display = new Display();
shell = new Shell(display);
shell.setLayout(new FillLayout());
Button switchButton = new Button(shell, SWT.PUSH);
switchButton.setText("Switch");
switchButton.setLayoutData(new GridData());
switchButton.addSelectionListener(new SelectionAdapter() {
public void widgetSelected(SelectionEvent event) {
if (currentCompositeNumber == 0) {
layout.topControl = composite1;
currentCompositeNumber = 1;
} else {
SWT.DEFAULT));
stack.layout();
new ScrollAndStack();
shell.pack();
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch()) {
display.sleep();
display.dispose();
class Composite0 extends Composite {
public Composite0(Composite parent, int style) {
super(parent, style);
setLayout(new GridLayout());
Text text;
for (int i = 0; i < 5; i++) {
text = new Text(this, SWT.NONE);
text.setText("Composite0 Text " + i);
text.setLayoutData(new GridData());
class Composite1 extends Composite {
public Composite1(Composite parent, int style) {
Text text;
for (int i = 0; i < 30; i++) {
text.setText("Composite1 Text " + i);
Re: ScrolledComposite and StackLayout [message #459414 is a reply to message #459412] |
Tue, 09 August 2005 05:13   |
Originally posted by: friederich.kupzog.de
Hi Hortiz,
this is normal. The size of the StackLayout composite is alsways as big
as the biggest component. So, you answered your question yourself :)
Friederich
hortiz wrote:
> StackLayout layout.
> on the stack ?
> import org.eclipse.swt.widgets.Display;
> SWT.V_SCROLL);
> stack.layout();
> public static void main(String[] args) {
> } else {
> SWT.DEFAULT));
> stack.layout();
> shell.pack();
> shell.open();
> display.sleep();
> display.dispose();
> Text text;
> Text text;
Friederich Kupzog
Elektronik & Software
Neusser Str. 5-7
50670 Köln
Tel 0241 160696-1
Fax 0221 726670
www.kupzog.de/fkmk
Re: ScrolledComposite and StackLayout [message #459558 is a reply to message #459416] |
Wed, 10 August 2005 11:57  |
--____MFYVKBDZBDVYBGCLQMQX____
Content-Type: text/plain; charset=iso-8859-1
Content-Transfer-Encoding: quoted-printable
Content-Disposition: inline; modification-date="Thu, 10 Aug 2005 05:57:03
-0500"
I didn't like the empty white space left from the largest component when =
the smallest was displayed, so each time I change the stack, I recompute =
the size of the current composite and tell the scrolledComposite the new =
height. (In my case the width doesn't change.)
m_scrolledComposite.setMinHeight(computeSize(SWT.DEFAULT, =
SWT.DEFAULT).y);
Joe
Content-Type: multipart/related; boundary="____PGJMUKIBGYUINCFOMJHW____"
--____PGJMUKIBGYUINCFOMJHW____
Content-Type: text/html; charset=windows-1252
Content-Disposition: attachment; filename="Text.htm";
modification-date="Thu, 10 Aug 2005 05:57:03 -0500"
<HTML><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; charset=3Diso-8859-1"=
<META content=3D"MSHTML 6.00.2800.1515" name=3DGENERATOR></HEAD>
<BODY style=3D"MARGIN: 4px 4px 1px; FONT: 10pt Tahoma">
<DIV>I didn't like the empty white space left from the largest component =
when the smallest was displayed, so each time I change the stack, I =
recompute the size of the current composite and tell the scrolledComposite =
the new height. (In my case the width doesn't change.)</DIV>
<DIV> </DIV>
<DIV> m_scrolledComposite.setMinH=
eight(computeSize(SWT.DEFAULT, SWT.DEFAULT).y);</DIV>
<DIV> </DIV>
<DIV>Joe<BR></DIV></BODY></HTML>
--____PGJMUKIBGYUINCFOMJHW____--
--____MFYVKBDZBDVYBGCLQMQX____--
FUDForum. Page generated in 0.48048 seconds
