Home » Eclipse Projects » Rich Client Platform (RCP) » How to open an login dialog before the Window is initialized
How to open an login dialog before the Window is initialized [message #459283] Wed, 29 November 2006 22:33 Go to next message
Originally posted by: florianwendland.freenet.de
Hello all,
i have a problem concerning the initialization og an dialog before the
window is drawn.
I want to realize a login dialog, where the user can chose his profile.
Then, the profile settings will be load into the PreferenceStore.
My problem is, that there is no shell, which i can pass to the dialog,
before the window was initialized.
Is there another way to work around that problem?
Thx
Florian
Ich verwende die kostenlose Version von SPAMfighter,
die bei mir bis jetzt 3495 Spammails entfernt hat.
F
Re: How to open an login dialog before the Window is initialized [message #459285 is a reply to message #459283] Wed, 29 November 2006 23:24 Go to previous messageGo to next message
Originally posted by: partyhut.internode.on.net
Hi Florian,
I guess you are extending ApplicationWindow... You can work around it by
create a Display in your main method.
Just do something like this:
public class MyClass extends ApplicationWindow
static Display display;
public static void main(String args[])
try
display = new Display();
Then you can open your dialog in createContents. Hope that helps.
Henry
Florian Wendland wrote:
> Hello all,
> window is drawn.
> Thx
> Florian
> Für private Anwender ist SPAMfighter völlig kostenlos!
> Jetzt gratis testen: hier klicken.
Re: How to open an login dialog before the Window is initialized [message #459369 is a reply to message #459285] Thu, 30 November 2006 12:44 Go to previous messageGo to next message
No,
i'm inside of RCP and there is no main method.
I need a way to crweate a shell before the rcp window is opened.
Thx
die bei mir bis jetzt 3529 Spammails entfernt hat.
F
Re: How to open an login dialog before the Window is initialized [message #459374 is a reply to message #459369] Thu, 30 November 2006 16:29 Go to previous message
In your Application class (i.e the one implementing IPlatformRunnable),
there is a run(args) method, so use that one:
public Object run(Object args) throws Exception {
Display display = PlatformUI.createDisplay();
boolean pass = false;
while (!pass) {
Thread.sleep(2000);
Platform.endSplash();
LoginDialog dlg = new LoginDialog(null);
if (Window.OK == dlg.open()) {
String username = dlg.getUsername();
String password = dlg.getPassword();
if (<DO_AUTHENTICATE_HERE>) {
pass = true;
} else {
return IPlatformRunnable.EXIT_OK;
try {
int returnCode = PlatformUI.createAndRunWorkbench(display, new
ApplicationWorkbenchAdvisor());
if (returnCode == PlatformUI.RETURN_RESTART) {
return IPlatformRunnable.EXIT_RESTART;
} finally {
display.dispose();
> No,
> Thx
Previous Topic:Marker in node XML
Next Topic:Using a Java Agent (e.g. Spring/Toplink) with an Eclipse RCP app?
Current Time: Sun Jul 20 15:35:30 EDT 2025
Powered by FUDForum. Page generated in 0.03917 seconds
