Home » Eclipse Projects » Standard Widget Toolkit (SWT) » May I make checkbox of table read_only?
May I make checkbox of table read_only? [message #459175] Wed, 03 August 2005 04:45 Go to next message
I'm using the standard table of swt with SWT.CHECK style. But sometimes
I hope it's read_only to user.
Is there an API for this purpose?
Thanks a lot!
James Gan
Re: May I make checkbox of table read_only? [message #459206 is a reply to message #459175] Wed, 03 August 2005 08:04 Go to previous messageGo to next message
Not as such afaict...
You can however make it visually "disabled" by gray'ing it out and
resetting it's value in a listener whenever somebody tries to change
it's checked state.
James Gan kirjutas mulle ühel talvisel päeval midagi seesugust:
> Thanks a lot!
> James Gan
Roland Tepp
Re: May I make checkbox of table read_only? [message #459247 is a reply to message #459206] Thu, 04 August 2005 07:58 Go to previous messageGo to next message
Thank you for the answer. Maybe I should disable the entitle table :)
> it's checked state.
>> Hi,
>> sometimes I hope it's read_only to user.
>> Thanks a lot!
>> James Gan
Re: May I make checkbox of table read_only? [message #459302 is a reply to message #459247] Fri, 05 August 2005 03:38 Go to previous message
>> it's checked state.
>>> Hi,
>>> Thanks a lot!
>>> James Gan
You could also use an image of a checked checkbox to display in the
column. That way no one is able to uncheck it.
HTH
Stefan
Previous Topic:SWT newbie question
Next Topic:Keyboard shortcuts disappeard ?
Current Time: Sat Jul 19 09:32:21 EDT 2025
Powered by FUDForum. Page generated in 0.04061 seconds
