Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Label "cut" in wizard page
Label "cut" in wizard page [message #459036] Fri, 29 July 2005 09:20 Go to next message
Hello !
I have some labels on a wizard page. It worked fine until I decided to
use tabs ("\t") to align words. Now the end of some words is cut :
Screenshot : http://img288.imageshack.us/img288/6923/labelcut4ad.jpg
Does anybody know why this happens ? Thanks
Vincent
Re: Label "cut" in wizard page [message #459037 is a reply to message #459036] Fri, 29 July 2005 09:21 Go to previous messageGo to next message
Vincent Etter wrote:
> Hello !
> Vincent
The text must be :
Inclure les fichiers cachés : Non
Inclure les sous-répertoires : Oui
Re: Label "cut" in wizard page [message #459058 is a reply to message #459037] Fri, 29 July 2005 10:48 Go to previous messageGo to next message
Originally posted by: sunil_kamath.nohotspammail.com
"Vincent Etter" <vincent.etter@gmail.com> wrote in message
news:dcdagn$r95$2@news.eclipse.org...
>> Hello !
>> Vincent
> The text must be :
Re: Label "cut" in wizard page [message #459059 is a reply to message #459058] Fri, 29 July 2005 11:10 Go to previous messageGo to next message
>>>Hello !
>>>Vincent
>>The text must be :
> Did you try increasing the width of the labels manually?
> Or, if you are using GridLayout, you could set
> GridData.grabExcessHorizontalSpace = true.
> AFAIK, When a component calculates its preferred size, it doesn't
> distinguish between normal characters and special characters.
> It uses an average character width multiplied by the number of characters.
> Sunil
I "packed" my labels but didn't try to increase their size manually. I
solved the problem with formlayouts. Thanks for your answer ! It's good
to know that size is "estimanted" and not really calculated...
Vincent
Re: Label "cut" in wizard page [message #459475 is a reply to message #459059] Tue, 09 August 2005 17:10 Go to previous message
>> characters.
This is not correct. For example, custom widget in SWT use
GC.textExtent(String string, int flags) where the flags specify whether
tabs, mnemonis, or delimiters should be considered when measuring string
lengths. This is also true of native widgets. In cases where this is found
to not be true, you should enter bug reports.
news:dcdgtu$4em$1@news.eclipse.org...
>>>>Hello !
>>>>Vincent
>>>The text must be :
Previous Topic:Which platforms do not support controlling native drags?
Next Topic:Why is there not SWT.CAP_* in my eclipse3.1?
Current Time: Sat Jul 19 13:28:56 EDT 2025
Powered by FUDForum. Page generated in 0.28890 seconds
