Home » Eclipse Projects » Standard Widget Toolkit (SWT) » SWT exception kills VM
SWT exception kills VM [message #458972] Wed, 27 July 2005 11:28
Originally posted by: berndvogt.gmx.de
I get a serious SWT exception while running a FormEditor and can't
imagine why it occures...
The FormEditor consists of two pages:
1. Formpage with a TreeViewer
2. TextEditor
The exception appears:
1. Editor is Open
2. I change the name of the project -> the editor gets an new
IFileEditorInput (with the new location)
3. I switch the editor pages some times
4. I rename the project again
-> VM brakes down...
Any ideas? Is this an SWT bug?
The exception:
An unexpected exception has been detected in native code outside the VM.
Unexpected Signal : EXCEPTION_ACCESS_VIOLATION (0xc0000005) occurred at
PC=0x717635F5
Function=CreateToolbar+0x9CDF
Library=C:\WINNT\system32\COMCTL32.DLL
Current Java thread:
at org.eclipse.swt.internal.win32.OS.CallWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.CallWindowProc(OS.java:139 7)
at org.eclipse.swt.widgets.Tree.callWindowProc(Tree.java:170)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3050 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:3338 )
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:14 73)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2429)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1377)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1348)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:254)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at
at
at java.lang.reflect.Method.invoke(Method.java:324)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:704)
at org.eclipse.core.launcher.Main.main(Main.java:688)
Dynamic libraries:
0x00400000 - 0x0040B000 C:\Programme\Java\j2sdk1.4.2_06\bin\javaw.exe
0x77880000 - 0x77903000 C:\WINNT\system32\ntdll.dll
0x79350000 - 0x793B2000 C:\WINNT\system32\ADVAPI32.dll
0x77E70000 - 0x77F30000 C:\WINNT\system32\KERNEL32.DLL
0x77D20000 - 0x77D91000 C:\WINNT\system32\RPCRT4.DLL
0x77E00000 - 0x77E5F000 C:\WINNT\system32\USER32.dll
0x77F40000 - 0x77F7B000 C:\WINNT\system32\GDI32.dll
0x78000000 - 0x78045000 C:\WINNT\system32\MSVCRT.dll
0x08000000 - 0x08139000
C:\Programme\Java\j2sdk1.4.2_06\jre\bin\client\jvm.dll
0x77540000 - 0x77571000 C:\WINNT\system32\WINMM.dll
0x10000000 - 0x10007000 C:\Programme\Java\j2sdk1.4.2_06\jre\bin\hpi.dll
0x007E0000 - 0x007EE000 C:\Programme\Java\j2sdk1.4.2_06\jre\bin\verify.dll
0x007F0000 - 0x00809000 C:\Programme\Java\j2sdk1.4.2_06\jre\bin\java.dll
0x00810000 - 0x0081D000 C:\Programme\Java\j2sdk1.4.2_06\jre\bin\zip.dll
0x18170000 - 0x1818C000 C:\Programme\Java\j2sdk1.4.2_06\jre\bin\jdwp.dll
0x1C190000 - 0x1C195000
C:\Programme\Java\j2sdk1.4.2_06\jre\bin\dt_socket.dll
0x74FA0000 - 0x74FB4000 C:\WINNT\system32\ws2_32.dll
0x74F90000 - 0x74F98000 C:\WINNT\system32\WS2HELP.DLL
0x77830000 - 0x7783C000 C:\WINNT\System32\rnr20.dll
0x77970000 - 0x77994000 C:\WINNT\system32\DNSAPI.DLL
0x74FC0000 - 0x74FC9000 C:\WINNT\system32\WSOCK32.DLL
0x77310000 - 0x77323000 C:\WINNT\system32\iphlpapi.dll
0x774F0000 - 0x774F5000 C:\WINNT\system32\ICMP.DLL
0x772F0000 - 0x77307000 C:\WINNT\system32\MPRAPI.DLL
0x750C0000 - 0x750CF000 C:\WINNT\system32\SAMLIB.DLL
0x750E0000 - 0x7512F000 C:\WINNT\system32\NETAPI32.DLL
0x79430000 - 0x7943F000 C:\WINNT\system32\Secur32.dll
0x77BE0000 - 0x77BF1000 C:\WINNT\system32\NTDSAPI.dll
0x77940000 - 0x7796B000 C:\WINNT\system32\WLDAP32.DLL
0x75130000 - 0x75136000 C:\WINNT\system32\NETRAP.dll
0x77A40000 - 0x77B2F000 C:\WINNT\system32\OLE32.DLL
0x779A0000 - 0x77A3B000 C:\WINNT\system32\OLEAUT32.DLL
0x77380000 - 0x773B0000 C:\WINNT\system32\ACTIVEDS.DLL
0x77350000 - 0x77373000 C:\WINNT\system32\ADSLDPC.DLL
0x77820000 - 0x7782E000 C:\WINNT\system32\RTUTILS.DLL
0x78310000 - 0x783A1000 C:\WINNT\system32\SETUPAPI.DLL
0x791A0000 - 0x79202000 C:\WINNT\system32\USERENV.DLL
0x774B0000 - 0x774E3000 C:\WINNT\system32\RASAPI32.DLL
0x77490000 - 0x774A1000 C:\WINNT\system32\RASMAN.DLL
0x77500000 - 0x77522000 C:\WINNT\system32\TAPI32.DLL
0x71710000 - 0x71794000 C:\WINNT\system32\COMCTL32.DLL
0x70A70000 - 0x70AD6000 C:\WINNT\system32\SHLWAPI.DLL
0x77330000 - 0x77349000 C:\WINNT\system32\DHCPCSVC.DLL
0x777D0000 - 0x777D8000 C:\WINNT\System32\winrnr.dll
0x777E0000 - 0x777E5000 C:\WINNT\system32\rasadhlp.dll
0x74F40000 - 0x74F5E000 C:\WINNT\system32\msafd.dll
0x74F80000 - 0x74F87000 C:\WINNT\System32\wshtcpip.dll
0x1CA20000 - 0x1CA2F000 C:\Programme\Java\j2sdk1.4.2_06\jre\bin\net.dll
0x1CA30000 - 0x1CA38000 C:\Programme\Java\j2sdk1.4.2_06\jre\bin\nio.dll
0x1CE90000 - 0x1CEDE000
C:\eclipse_3.0.1\plugins\org.eclipse.swt.win32_3.0.1\os\win3 2\x86\swt-win32-3063.dll
0x76B00000 - 0x76B3F000 C:\WINNT\system32\comdlg32.dll
0x77580000 - 0x777CB000 C:\WINNT\system32\SHELL32.DLL
0x75DF0000 - 0x75E0A000 C:\WINNT\system32\IMM32.dll
0x664B0000 - 0x66504000 C:\WINNT\system32\USP10.dll
0x694D0000 - 0x694EF000 C:\WINNT\system32\oleacc.dll
0x6B150000 - 0x6B155000 C:\WINNT\system32\msimg32.dll
0x1D2D0000 - 0x1D30E000 C:\Programme\Network
Associates\VirusScan\Wbhook32.dll
0x77810000 - 0x77817000 C:\WINNT\system32\VERSION.dll
0x75940000 - 0x75946000 C:\WINNT\system32\LZ32.DLL
0x1D420000 - 0x1D42A000 C:\Programme\Network
Associates\VirusScan\Res07\WbhkRes.dll
0x1D430000 - 0x1D438000
C:\eclipse_3.0.1\plugins\org.eclipse.core.resources.win32_3. 0.0\os\win32\x86\core_2_1_0b.dll
0x77910000 - 0x77933000 C:\WINNT\system32\imagehlp.dll
0x72970000 - 0x7299D000 C:\WINNT\system32\DBGHELP.dll
0x68F30000 - 0x68F3B000 C:\WINNT\system32\PSAPI.DLL
Heap at VM Abort:
Heap
def new generation total 3136K, used 1117K [0x10010000, 0x10370000,
0x104f0000)
eden space 2816K, 28% used [0x10010000, 0x100d7678, 0x102d0000)
from space 320K, 99% used [0x102d0000, 0x1031fff8, 0x10320000)
to space 320K, 0% used [0x10320000, 0x10320000, 0x10370000)
tenured generation total 41008K, used 36904K [0x104f0000,
0x12cfc000, 0x14010000)
the space 41008K, 89% used [0x104f0000, 0x128fa160, 0x128fa200,
0x12cfc000)
compacting perm gen total 24320K, used 24185K [0x14010000,
0x157d0000, 0x18010000)
the space 24320K, 99% used [0x14010000, 0x157ae478, 0x157ae600,
0x157d0000)
Local Time = Wed Jul 27 11:17:51 2005
Elapsed Time = 109
# The exception above was detected in native code outside the VM
# Java VM: Java HotSpot(TM) Client VM (1.4.2_06-b03 mixed mode)
Previous Topic:How to scroll a table to its end
Next Topic:Importing images from MS Access
Current Time: Sun Jul 20 18:20:27 EDT 2025
Powered by FUDForum. Page generated in 0.24068 seconds
