need a check comboBox [message #453967] |
Fri, 15 April 2005 02:54  |
hi,
i need a combo box where you can check/select values in the comboBox? is
this available in swt?
thx mseele
Re: need a check comboBox [message #453976 is a reply to message #453973] |
Fri, 15 April 2005 06:46   |
Originally posted by: martin.j.nilsson.sverige.nu
Michael Seele wrote:
> mozilla thunderbird uses a checkable combo box for
> filtering(right-upper edge)...
Ah, I have never noticed that although I run ThunderBird myself at home. I
realise now that I should have been a bit more verbose in my previous
posting.
This is my idea of SWT:
A GUI class library for making applications
that uses the native widgets of the different
operating systems, enabling applications to
look native although they in reality are
cross-platform.
I know there is lots more to SWT and I do not mean any offence to anyone
of the bright minds behind SWT, but this is basically why I use SWT
instead of SWING. Well, that and the ease of use.
I mostly develop for Windows and in that respect SWT is feature complete
for me, I haven't found any native widgets in Windows which can't be used
in SWT (perhaps there are some, but I haven't found/needed them). This
enables me to write applications that really look like something that
Microsoft themselves could have released (if that is something to
desire... :-). It helps me to enhance the usability of my programs by
restricting me to widgets that feels well-known to my users [1].
This restriction of SWT is actually an important thing for me, I know I
can extend SWT and probably make any kind of strange widgets that I'd
like, but this should be discouraged and new custom widgets should only be
created if all else fails (in my book at least). I've a long time ago
realised that although Windows XP and for example OSX look very
dissimilar, they are both founded on a lot of deep thinking about
usability and it is not likely that I would know better than the designers
of the OS.
Although I like ThunderBird very much I'm not sure that the creators share
my opinions. I deeply believe that it is not my place to extend the OS
with new widgets, I should work with the tools they have given me (via SWT
in this case) and accept the limits this gives me.
Well, perhaps I better stop this long-windedness before I start to sound
religious, I hope I've explained my point. If a checkbox-combo really is a
part of Windows, you can pretty much ignore these ramblings. Otherwise, I
would humbly suggest that there is another way to do exactly the same
thing you are trying to do, but with widgets more well known to your users.
I know that this is not the answer you wanted, please accept my apologies
for that, but perhaps you can find some meaning in what I've written
anyway.
kind regards,
martin
[1] As a side-note, SWT/Eclipse has created more java-converts than any
other java-technology I know of ("Wow, that looks really nice and is
really responsive, is that really done in Java?").
Re: need a check comboBox [message #458867 is a reply to message #458865] |
Mon, 25 July 2005 04:22  |
Vincent,
>> A combo box is a 1 out of N selection element.
>> What you need is a M out of N selection element.
> Exactly ;) !
>> Why don't you use a button in combination with a dialog which displays
>> a list where each entry has a checkbox. JFace provides that.
>> If you want to show the selection near the button, then place a label
>> in front or after it.
> It could be a solution, but how can I place the dialog so that it seems
> to "roll out" from the button ? (Hope you'll understant me, my english
> is a little... limited ;) !)
Why is it so important to let it look like a combo box? It is not a
combo box. So don't irritate your users.
Maybe a button labeled "..." or "Filter..." is sufficient for your
needs. But try to label it more meaningful.
Look at the "Filters..." view menu item on the resource navigator or the
filter toolbar button on the problem view. They oben a little dialog
which includes a list with checkboxes.
Daniel
FUDForum. Page generated in 0.06545 seconds
