Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Want to show Tree selection when tree does not have focus
Want to show Tree selection when tree does not have focus [message #458665] Mon, 18 July 2005 15:27 Go to next message
I have a composite control that contains two Tree controls. The selected
item in each tree is shown only when the particular tree has focus. I would
like to be able to highlight or show the selected items in both trees
regardless of which has focus. Is there any way to do this?
I have tried doing things like changing the background color of the selected
item in the tree that has lost focus, but I do not seem to be able to get
the tree to refresh/repaint until it is back in focus again.
Any ideas on how to do this?
Agnes
Re: Want to show Tree selection when tree does not have focus [message #458695 is a reply to message #458665] Tue, 19 July 2005 11:10 Go to previous messageGo to next message
What platform are you running on? This sounds like a bug.
"Agnes Freese" <afreese@siebel.com> wrote in message
news:dbgvrq$g3k$1@news.eclipse.org...
> would
> selected
> Agnes
Re: Want to show Tree selection when tree does not have focus [message #458699 is a reply to message #458695] Tue, 19 July 2005 11:35 Go to previous messageGo to next message
OS Name Microsoft Windows XP Professional
Version 5.1.2600 Service Pack 2 Build 2600
"Veronika Irvine" <veronika_irvine@oti.com> wrote in message
news:dbj54n$th5$1@news.eclipse.org...
> > Hi,
selected
> > would
> > selected
get
> > Thanks,
> > Agnes
Re: Want to show Tree selection when tree does not have focus [message #458714 is a reply to message #458699] Tue, 19 July 2005 16:48 Go to previous messageGo to next message
On Windows XP with Service Pack 2, I see selection even when the tree does
not have focus.
The selection is blue when the tree has focus and gray when the tree does
not have focus but it is definitely visible.
Please enter a bug report against Platform SWT and we will try to figure out
what is the problem for you.
news:dbj6jf$vng$1@news.eclipse.org...
>> > Hi,
> selected
>> > would
>> > selected
> get
>> > Thanks,
>> > Agnes
Re: Want to show Tree selection when tree does not have focus [message #458716 is a reply to message #458714] Tue, 19 July 2005 20:30 Go to previous messageGo to next message
Hi Veronika,
Thanks for your response.
It appears that my problem is one of color selection. The Tree control in
3.1 with columns shows white grid lines. I got another response from
someone else saying that this was something that I cannot change. If you
can also verify this I would appreciate it.
Because of the white grid lines (TableTree used to have black or gray grid
lines), I had to set a color for the background of the Tree so I could see
the white lines. Unfortunately, the color I chose is the same as the
highlight color for the selected item when the tree is out of focus. When I
set the background back to white, I can see the selection.
It is rather disappointing that the grid lines are white in 3.1. This makes
it necessary to select colors for the background. Is there any chance of
some default color being selected for the background that is not white like
the lines so that the initial implementation will show the lines?
Agnes
news:dbjovd$nlh$1@news.eclipse.org...
> not have focus.
out
> >> > Hi,
> > selected
I
> >> > would
> >> > selected
> > get
> >> > Thanks,
> >> > Agnes
Re: Want to show Tree selection when tree does not have focus [message #458740 is a reply to message #458716] Wed, 20 July 2005 09:35 Go to previous messageGo to next message
For me the grid-lines are not white but a light gray colour. I have tried
with and without a manifest on Windows XP and in both cases I can see the
lines against the white background. I have tried with the Windows XP Style
with sub-design Blue(standard) and Silver - all work for me. Do you have a
windows skin applied to your desktop?
news:dbk5v3$3l3$1@news.eclipse.org...
> Hi Veronika,
> I
> makes
> like
> Agnes
>> does
>> not have focus.
> out
>> >> > Hi,
>> > selected
> I
>> >> > would
>> >> > trees
>> >> > selected
>> >> > to
>> > get
>> >> > Thanks,
>> >> > Agnes
Re: Want to show Tree selection when tree does not have focus [message #458897 is a reply to message #458740] Mon, 25 July 2005 15:05 Go to previous message
Hi Agnes,
Just to eliminate the obvious, you're NOT creating your Trees with style
SWT.HIDE_SELECTION or SWT.PRIMARY_MODAL, right?
Grant
news:dbljuk$jts$1@news.eclipse.org...
Style
a
> > Hi Veronika,
in
you
grid
see
When
> > I
> > makes
of
> > like
> > Thanks,
> > Agnes
> >> does
> >> not have focus.
does
figure
> > out
> >> >> > Hi,
> >> > selected
focus.
> > I
> >> >> > would
> >> >> > trees
the
> >> >> > selected
> >> >> > to
> >> > get
> >> >> > Thanks,
> >> >> > Agnes
Previous Topic:Cell focus in a table
Next Topic:Memory currently allocated by SWT?
Current Time: Sun Jul 20 08:47:54 EDT 2025
Powered by FUDForum. Page generated in 0.03694 seconds
