Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Rectangle/column selection in StyledText or any other SWT compatible text field
Rectangle/column selection in StyledText or any other SWT compatible text field [message #458413] Wed, 13 July 2005 03:47 Go to next message
Originally posted by: cyberfloetz.web.de
I'm searching for a solution to select columns inside a SWT text field. Does
anybody know how to do that?
You don't understand what I mean? --> Normally when you select some lines of
text the selection starts at the cursors X position left-top, selects the
rest of the line, the next lines and then ends at the cursor X position
right-bottom. But I'm searching for a rectangle selection/column selection.
Only the text between left-top position and the right-button selection shall
be selected and not the "rest/beginning" of the line. In M!cro$oft W0rd you
can do this by holding the "Alt" key when selecting the text.
Example: (text block letters: o; selected letters: 0)
Normal selection:
ooooooooooooooo
oooo00000000000
000000000000000
00000000ooooooo
ooooooooooooooo
What I search for:
ooooooooooooooo
oooo0000ooooooo
oooo0000ooooooo
oooo0000ooooooo
ooooooooooooooo
I know that this can be very difficult if you have to handle text with
non-monospaced fonts. But monospaced fonts would be enough. I also tried to
deactivate normal selection mode and put a graphical layer over it which
handels selection in a graphical way, but I didn't find a solution how to
create a layered SWT-Composite with Draw and SWT components inside...is that
possible in any way???
Thanks a lot an sorry for the bad english *blush*,
Andreas
Re: Rectangle/column selection in StyledText or any other SWT compatible text field [message #458525 is a reply to message #458413] Thu, 14 July 2005 10:24 Go to previous messageGo to next message
You won't be able to do this with either the native Text control or
StyledText. The operating systems don't support it.
"cyberfloetz" <cyberfloetz@web.de> wrote in message
news:db2gus$hh9$1@news.eclipse.org...
Does
of
selection.
shall
you
> Normal selection:
> ooooooooooooooo
> oooo00000000000
> 000000000000000
> 00000000ooooooo
> ooooooooooooooo
> What I search for:
> ooooooooooooooo
> oooo0000ooooooo
> oooo0000ooooooo
> oooo0000ooooooo
> ooooooooooooooo
to
that
> Andreas
Re: Rectangle/column selection in StyledText or any other SWT compatible text field [message #458989 is a reply to message #458413] Thu, 28 July 2005 09:36 Go to previous message
You may wish to CC yourself to
https://bugs.eclipse.org/bugs/show_bug.cgi?id=8521 .
Does
of
selection.
shall
you
> Normal selection:
> ooooooooooooooo
> oooo00000000000
> 000000000000000
> 00000000ooooooo
> ooooooooooooooo
> What I search for:
> ooooooooooooooo
> oooo0000ooooooo
> oooo0000ooooooo
> oooo0000ooooooo
> ooooooooooooooo
to
that
> Andreas
Previous Topic:Help with ComboBoxCellEditor in TableTreeViewer
Next Topic:how to handle treeviewer before expand happened ?
Current Time: Sat Jul 19 12:02:54 EDT 2025
Powered by FUDForum. Page generated in 0.03728 seconds
