eclipse perspective changes C to Java [message #457854] |
Sat, 01 August 2009 22:22 |
I'm evaluating this to run test cases in a CDT environment, which I
installed after the java tools, along with mingw C++ tools and gdb, as
suggested in the CDT notes.
I had a test case that already had excerpts from your java examples, and
then I started adding C test cases. One thing I noticed when was that
the default automatic perspective switching between Java and C
perspectives appeared to be the cause of a lot of failures. I put code in
the beforeClass() to turn off all the automatic perspective switching in
the preferences, and most of the problems disappeared. After this, I
just activate the perspectives I need during the run manually with code
like below.
SWTBotPerspective clangPerspective = bot.perspectiveByLabel("C/C++");
clangPerspective.activate();
Here's the added code in beforeClass;
bot = new SWTWorkbenchBot();
bot.viewByTitle("Welcome").close();
baseShell=bot.activeShell();
bot.menu("File").menu("Switch Workspace").menu("Other...").click();
bot.button("Cancel").click();
bot.menu("Window").menu("Preferences").click();
SWTBotShell prefsShell = bot.shell("Preferences");
prefsShell.activate();
// now bot is acting on prefsShell?
SWTBotTreeItem treeItem =
bot.tree().getTreeItem("Run/Debug").select().expand().click();
treeItem.getNode("Perspectives").select().expand().click();
// This form ignores the & in the label that creates the underscored
shortcut letter
bot.radioInGroup("Never","Open the associated perspective when
launching").click();
bot.radioInGroup("Never","Open the associated perspective when an
application suspends").click();
bot.button("OK").click();
bot.waitUntil(shellCloses(prefsShell));
treeItem =
bot.tree().getTreeItem("General").select().expand().click();
shortcut letter
bot.radioInGroup("Never open","Open the associated perspective when
creating a new project").click();
FUDForum. Page generated in 0.26271 seconds
