Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Dnd Problems on a Tree
Dnd Problems on a Tree [message #455958] Tue, 24 May 2005 04:44 Go to next message
Originally posted by: ssc.acentic.net
I have a tree with drag and drop which works fine so far.
I created a object "Book" which I attach to the treeItem with setData.
This also works fine.
The problem appears when I drag and drop a treeitem, I am not able to
transfer the object to the new treeitem. Getting the name is not a
problem, but the object is.
I use this to get the name :
public void drop (DropTargetEvent event) {
if (event.data == null) {
event.detail = DND.DROP_NONE;
return;
String text = (String) event.data;
which works ok, but how would I get the object. I assumed to do someting
like this :
Book mybook = (Book) event.data;
System.out.println(mybook.gettitle());
But that gave me a CastException.
Book mybook = (Book) event.item;
This works fine on the other hand, but unfortunately that gives me the
data of the drop target and not the source.
Hope anyone can help me out here.
Sebastian
Re: Dnd Problems on a Tree [message #455960 is a reply to message #455958] Tue, 24 May 2005 05:13 Go to previous messageGo to next message
actually I did a "workaround" if you can call it, just taking the class
defined
private Item dragSourceItem;
and this :
TreeItem tmpItem = (TreeItem)dragSourceItem;
Book mybook = (Book) tmpItem.getdata();
Now is that a good way to do this or any other suggestions ?
-Sebastian
Re: Dnd Problems on a Tree [message #456309 is a reply to message #455960] Mon, 30 May 2005 13:56 Go to previous message
You should define a data transfer type for Book. See:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.swt.sni ppets/src/org/eclipse/swt/snippets/Snippet79.java?rev=HEAD&a mp;content-type=text/vnd.viewcvs-markup
"Sebastian Scholz" <ssc@acentic.net> wrote in message
news:pan.2005.05.24.09.13.07.406000@acentic.net...
> Hi
> defined
> and this :
> -Sebastian
Previous Topic:Window title font
Next Topic:Safe to call setTransfer multiple times on a DragSource?
Current Time: Sat Jul 19 17:55:33 EDT 2025
Powered by FUDForum. Page generated in 0.06571 seconds
