Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Virtual Table
Virtual Table [message #455834] Thu, 19 May 2005 19:47 Go to next message
In case of virtual tables is it necessary to setItemCount() for it to work
properly? I have a case where item count is not know beforehand. If I dont
set item count, does it affect the scrollbar thumb size?
I also wanted to know if JFace TableViewer supports virtual tables (my guess
is no, but just want to confirm). Are there any plans of building that
support in near future?
Avneesh
Re: Virtual Table [message #455839 is a reply to message #455834] Fri, 20 May 2005 03:15 Go to previous messageGo to next message
> properly?
As far as i know setItemCount preallocates all TableItems and adjusts
the scollbar thumb size. Virtual Table is not designed to be used
without setItemcount. It may work or may not work.
It is supported in 3.1. You'll need an IlazyContentProvider and must(!)
call setItemCount on the TableViewer, setInput is not used for virtual
tables.
Re: Virtual Table [message #455848 is a reply to message #455839] Fri, 20 May 2005 06:40 Go to previous messageGo to next message
Well... OK! The JFace support the TableViewer with SWT.VIRTUAL, and you had
said that I'll need a IlazyContentProvider for use it, well... but how can
i use it, in other words where I found a example that use this type of
table? I've try to write a code but it not fuction very well... Can you help
me?
Stefano
"Yves Harms" <user@domain.invalid> ha scritto nel messaggio
news:d6k2t5$rb8$1@news.eclipse.org...
>> work
>> properly?
> As far as i know setItemCount preallocates all TableItems and adjusts the
> scollbar thumb size. Virtual Table is not designed to be used without
>> guess
> tables.
Re: Virtual Table [message #455911 is a reply to message #455848] Mon, 23 May 2005 08:08 Go to previous messageGo to next message
Step 1 - Get it working non-lazy first:
See this article to get an idea how it works non-lazy:
http://www.eclipse.org/articles/Article-Table-viewer/table_v iewer.html
Try to get your code working with that first. For further tips search
the swt newsgroup, there are already a couple of helpful threads.
Step 2 - now just some minor modifications and you're done:
Replace your call to the TableViewers setInput(...) with a call to
setItemCount.
Let you Contentprovider now implement ILazyContentProvider instead of
IStructuredContentProvider.
Thats it.
> me?
> Thanks
> Stefano
>>>work
>>>properly?
>>>guess
>>tables.
Re: Virtual Table [message #455935 is a reply to message #455911] Mon, 23 May 2005 11:04 Go to previous message
I'll try tonight... I'll see
news:d6sh9g$dr1$1@news.eclipse.org...
> Try to get your code working with that first. For further tips search the
> setItemCount.
> Thats it.
>> had said that I'll need a IlazyContentProvider for use it, well... but
>> how can i use it, in other words where I found a example that use this
>> type of table? I've try to write a code but it not fuction very well...
>> Can you help me?
>> Thanks
>> Stefano
>>>>work
>>>>properly?
>>>>guess
>>>tables.
Previous Topic:draw2d gridbaglayout similar to swing gridbag layout
Next Topic:Adding section in a section ?
Current Time: Sat Jul 19 10:51:47 EDT 2025
Powered by FUDForum. Page generated in 0.05566 seconds
