Home » Eclipse Projects » Standard Widget Toolkit (SWT) » MS-Mediaplayer don't work
MS-Mediaplayer don't work [message #454791] Thu, 28 April 2005 18:03 Go to next message
Originally posted by: schmuhan.web4schmutz.ch
I like to write a MediaPlayer-widget for WMP V9 acting like SWT.Browser.
I'm always receiving an unexpected exception if I activate it with:
site.doVerb(OLE.OLEIVERB_INPLACEACTIVATE);
An unexpected exception has been detected in native code outside the VM.
Unexpected Signal : EXCEPTION_ACCESS_VIOLATION (0xc0000005) occurred at
PC=0x4B64F839
Function=DllGetClassObject+0x2E8C4
Library=C:\WINNT\system32\wmp.dll
If I activate it with "OLEIVERB_SHOW" doesn't occur an exception but it
doesn't show the video using all the frame space.
I'm new to SWT and OLE and I hope you can give me same help or is this an
problem with MS-MediaPlayer?
Thanks Hanspeter
parts of the code:
public class MMediaPlayer extends Composite
OleFrame frame;
OleControlSite site;
OleAutomation auto;
public MMediaPlayer(Composite parent, int style)
super(parent, style & ~SWT.BORDER);
frame = new OleFrame(this, SWT.NONE);
try
site = new OleControlSite(frame, SWT.NONE, "WMPlayer.OCX.7");
//$NON-NLS-1$
catch (SWTException e)
dispose();
SWT.error(SWT.ERROR_NO_HANDLES);
auto = new OleAutomation(site);
public String getStatus()
checkWidget();
int[] rgdispid = auto.getIDsOfNames(new String[]
{ "status" }); //$NON-NLS-1$
Variant pVarResult = auto.getProperty(rgdispid[0]);
if (pVarResult == null || pVarResult.getType() != OLE.VT_BSTR)
return "";
String result = pVarResult.getString();
pVarResult.dispose();
return result;
public boolean isRemote()
checkWidget();
{ "isRemote" }); //$NON-NLS-1$
if (pVarResult == null || pVarResult.getType() != OLE.VT_BOOL)
return false;
boolean result = pVarResult.getBoolean();
return result;
public boolean setUiMode(String mode)
checkWidget();
if (mode == null) SWT.error(SWT.ERROR_NULL_ARGUMENT);
{ "uiMode" }); //$NON-NLS-1$
boolean result = auto.setProperty(rgdispid[0], new Variant(mode));
return result;
public boolean setMpEnabled(boolean mode)
checkWidget();
{ "enabled" }); //$NON-NLS-1$
return result;
public boolean setStretchToFit(boolean mode)
checkWidget();
int[] rgdispid = auto.getIDsOfNames(new String[]{ "stretchToFit"
}); //$NON-NLS-1$
return result;
public boolean setAutoStart(boolean mode)
checkWidget();
{ "settings" }); //$NON-NLS-1$
if (pVarResult == null || pVarResult.getType() == 0) return false;
OleAutomation settings = pVarResult.getAutomation();
rgdispid = settings.getIDsOfNames(new String[]
{ "autoStart" }); //$NON-NLS-1$
boolean result = settings.setProperty(rgdispid[0], new Variant(mode));
settings.dispose();
return result;
public boolean setWindowlessVideo(boolean mode)
checkWidget();
{ "windowlessVideo" }); //$NON-NLS-1$
return result;
public boolean setFullScreen(boolean mode)
checkWidget();
{ "fullScreen" }); //$NON-NLS-1$
return result;
public boolean setUrl(String url)
checkWidget();
if (url == null) SWT.error(SWT.ERROR_NULL_ARGUMENT);
{ "URL" }); //$NON-NLS-1$
boolean result = auto.setProperty(rgdispid[0], new Variant(url));
return result;
public void play()
checkWidget();
{ "controls" }); //$NON-NLS-1$
if (pVarResult == null || pVarResult.getType() == 0) return;
OleAutomation controls = pVarResult.getAutomation();
rgdispid = controls.getIDsOfNames(new String[]
{ "play" }); //$NON-NLS-1$
controls.invoke(rgdispid[0]);
controls.dispose();
public void stop()
checkWidget();
{ "stop" }); //$NON-NLS-1$
controls.dispose();
Re: MS-Mediaplayer don't work [message #454930 is a reply to message #454791] Mon, 02 May 2005 20:44 Go to previous messageGo to next message
Originally posted by: aaa.domain.invalid
Hanspeter,
When I used the ocx prog id , it crashes but with the following it seems
to work fine...
controlSite = new
OleControlSite(frame,SWT.NONE,"MediaPlayer.MediaPlayer.1");
-chhil
> PC=0x4B64F839
> an problem with MS-MediaPlayer?
> Thanks Hanspeter
> parts of the code:
> OleFrame frame;
> OleAutomation auto;
> try
> //$NON-NLS-1$
> dispose();
> checkWidget();
> return "";
> return result;
> checkWidget();
> return false;
> return result;
> checkWidget();
> return result;
> checkWidget();
> return result;
> checkWidget();
> int[] rgdispid = auto.getIDsOfNames(new String[]{ "stretchToFit" });
> //$NON-NLS-1$
> return result;
> checkWidget();
> settings.dispose();
> return result;
> checkWidget();
> return result;
> checkWidget();
> return result;
> checkWidget();
> return result;
> public void play()
> checkWidget();
> controls.dispose();
> public void stop()
> checkWidget();
> controls.dispose();
Re: MS-Mediaplayer don't work [message #454945 is a reply to message #454930] Tue, 03 May 2005 10:21 Go to previous messageGo to next message
yes I know, but "MediaPlayer.MediaPlayer.1" is Media Player 6.4 ActiveX
control (which is deprecated by MS) and "WMPlayer.OCX.7" is 'Windows Media
Player 9 Series ActiveX control' with an other interface.
Hanspeter
Re: MS-Mediaplayer don't work [message #455198 is a reply to message #454791] Tue, 10 May 2005 06:52 Go to previous message
Hi Hanspeter
I have used the following statements:
setLayout(new FillLayout());
frame = new OleFrame(this, SWT.BORDER);
frame.setSize(246, 250);
site = new OleControlSite(frame, SWT.NONE, "WMPlayer.OCX");
mediaPlayer = new MediaPlayer(auto);
site.doVerb(OLE.OLEIVERB_SHOW);
And then I added the following statement that magically prevents a crash
when closing the widget.
// Prevent crash of JVM at shutdown of player
setFocus();
After that I do some initialization of the player.
The computeSize() is overridden:
int w = mediaPlayer.getImageSourceWidth();
int h = mediaPlayer.getImageSourceHeight();
size.x = (w == 0 ? 246 : w);
size.y = (h == 0 ? 250 : h);
return size;
It is very difficult to get it right, I don't know who to blame.
Kind regards,
Jaap Reitsma
"Hanspeter" <schmuhan@web4schmutz.ch> wrote in message
news:8429e3e06470fbba075bce3049885ac1$1@www.eclipse.org...
> PC=0x4B64F839
> Thanks Hanspeter
> parts of the code:
> OleFrame frame;
> OleAutomation auto;
> try
> //$NON-NLS-1$
> dispose();
> checkWidget();
> if (pVarResult == null || pVarResult.getType() != OLE.VT_BSTR) return
> return result;
> checkWidget();
> if (pVarResult == null || pVarResult.getType() != OLE.VT_BOOL) return
> false;
> return result;
> checkWidget();
> return result;
> checkWidget();
> return result;
> checkWidget();
> //$NON-NLS-1$
> return result;
> checkWidget();
> settings.dispose();
> return result;
> checkWidget();
> return result;
> checkWidget();
> return result;
> checkWidget();
> return result;
> public void play()
> checkWidget();
> controls.dispose();
> public void stop()
> checkWidget();
> controls.dispose();
Previous Topic:Only able to edit first column in a tableviewer
Next Topic:SWT & Palm OS
Current Time: Sat Jul 19 16:12:31 EDT 2025
Powered by FUDForum. Page generated in 0.05325 seconds
