Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Text field that allows only currency entry
Text field that allows only currency entry [message #454972] Tue, 03 May 2005 14:16 Go to next message
Originally posted by: shorten5273.hotmail.com
I'm a new SWT / Eclipse user and I'm looking for a simple way of
creating a text entry field into which a user may enter only a dollar
amount ($46.78 for instance). I am not concerned at this point in
internationalization as this is an in-house project and will not need to
be used in non-dollar countries. My ideal widget would only allow a user
to enter numeric digits and $,.
but having the widget perform some type of validation after an entire
entry has been made would also work.
Any hints /help would be appreciated.
rs
Re: Text field that allows only currency entry [message #454976 is a reply to message #454972] Tue, 03 May 2005 15:42 Go to previous messageGo to next message
The Text widget can have a VerifyListener, which will allow you to
modify and cancel key events. Of course, you will need to implement
your own pattern matching. There may also be a JFace class which does
this, although I don't know which one.
Charlie
> rs
Re: Text field that allows only currency entry [message #454982 is a reply to message #454976] Tue, 03 May 2005 17:10 Go to previous messageGo to next message
See:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.swt.sni ppets/src/org/eclipse/swt/snippets/Snippet179.java?rev=HEAD& amp;content-type=text/vnd.viewcvs-markup
This snippet formats a date but the concept could be used to format
currency.
"Charlie Surface" <csurface@us.ibm.com> wrote in message
news:d58ki3$vkj$1@news.eclipse.org...
> The Text widget can have a VerifyListener, which will allow you to modify
> and cancel key events. Of course, you will need to implement your own
> pattern matching. There may also be a JFace class which does this,
> Charlie
> shorten5273 wrote:
>> I'm a new SWT / Eclipse user and I'm looking for a simple way of creating
>> a text entry field into which a user may enter only a dollar amount
>> rs
Re: Text field that allows only currency entry [message #454990 is a reply to message #454972] Wed, 04 May 2005 08:39 Go to previous messageGo to next message
> rs
Try this site:
http://www.swtworkbench.com/devzone/edwiki.cgi/Essential_Dat a_Home
Re: Text field that allows only currency entry [message #455092 is a reply to message #454972] Fri, 06 May 2005 00:18 Go to previous message
Thanks everyone. Good tips.
Previous Topic:Can widgets be added to a tree
Next Topic:refreshing bottom pane
Current Time: Sat Jul 19 20:52:58 EDT 2025
Powered by FUDForum. Page generated in 0.04793 seconds
