Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Unable to set background color of an SWT Button
Unable to set background color of an SWT Button [message #454216] Tue, 19 April 2005 04:41 Go to next message
I have Eclipse 3.0.1 under windows XP.
I have created a simple SWT Shell (window), with the help of the Visual
Editor Plugin.
By using the setBackground(...) method, I can easily change the
background of a label. But when I do the same to a button, it just
ignores me.
Is that normal? Is it a bug? A missing feature which will be available
in a later version? Or is it that the OS Look and Feel prevails for
this?
In any case... is there a workaround for this limitation? I could
change the whole OS Look and Feel, but this is too radical, and also in
my application I will need to have buttons of different colors
depending on its functionality.
The only workaround I can think of is to do like Swing does and write my
own button component from scratch. That looks too much like a brute force
approach.
Thanks for your help,
Luis.
Re: Unable to set background color of an SWT Button [message #454236 is a reply to message #454216] Tue, 19 April 2005 11:30 Go to previous messageGo to next message
Originally posted by: aaa.domain.invalid
Hello Luis,
This is currently not possible on windows and there is bug report filed
in bugzilla.
-chhil
Luis wrote:
> Hello,
> I have Eclipse 3.0.1 under windows XP. I have created a simple SWT Shell
> (window), with the help of the Visual Editor Plugin.
> ignores me.
> in a later version? Or is it that the OS Look and Feel prevails for this?
> In any case... is there a workaround for this limitation? I could change
> the whole OS Look and Feel, but this is too radical, and also in my
> application I will need to have buttons of different colors depending on
> its functionality.
> force approach.
> Luis.
Re: Unable to set background color of an SWT Button [message #454283 is a reply to message #454236] Tue, 19 April 2005 11:51 Go to previous messageGo to next message
Thank you, now this makes a lot of sense.
I have been searching in eclipse bugzilla but could not find the bug (I got
too 200 hits for "button background swt windows").
Could you give me the bug number?
Luis.
"Chhil" <aaa@domain.invalid> wrote in message
news:d438nb$el6$1@news.eclipse.org...
> Hello Luis,
> in bugzilla.
> -chhil
> Luis wrote:
> > Hello,
> > ignores me.
this?
> > its functionality.
> > force approach.
> > Luis.
Re: Unable to set background color of an SWT Button [message #454287 is a reply to message #454283] Tue, 19 April 2005 12:44 Go to previous messageGo to next message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=23837
-chhil
Re: Unable to set background color of an SWT Button [message #454493 is a reply to message #454236] Fri, 22 April 2005 11:27 Go to previous messageGo to next message
I did a quick test in C# with MS Visual Studio 2003 and I was able to change
the background color of a Windows button:
System.Windows.Forms.Button but;
but=new System.Windows.Forms.Button();
but.BackColor = System.Drawing.Color.Aquamarine;
With the code above you can get a nice aquamarine button in Windows.
I am pretty sure that, unlike Swing, C# and .NET do not emulate buttons but
use the standard Windows ones. That is, as far as I understand, that code
eventually invokes the standard Windows system GUI primitives.
So I don't understand why the bug appears as "WONTFIX"
> Hello Luis,
> in bugzilla.
> -chhil
> Luis wrote:
> > Hello,
> > ignores me.
this?
> > its functionality.
> > force approach.
> > Luis.
Re: Unable to set background color of an SWT Button [message #454505 is a reply to message #454493] Sat, 23 April 2005 15:34 Go to previous messageGo to next message
Unless it's doable on all platforms that SWT supports, chaning the button
color won't be added even if it's doable on Windows. It doesn't surprise me
that C# lets you do it if it's in the windows API.
If you don't care about cross-platform compatability for you app (or you
only do the needed calls if you're on Windows), you can just make the
necessary SendMessage calls on the win32 OS api that SWT comes with.
Here's some API info regarding themes and changing them:
http://msdn.microsoft.com/library/default.asp?url=/library/e n-us/dnwxp/html/xptheming.asp
And a google search on "win32 changing button color" will get you more info.
Hope that helps,
Emil
"Luis" <lcrespom@gmail.com> wrote in message
news:d4b589$jqs$1@news.eclipse.org...
> Hello,
> change
> but
>> Hello Luis,
>> in bugzilla.
>> -chhil
>> Luis wrote:
>> > Hello,
>> > Shell
>> > ignores me.
> this?
>> > change
>> > on
>> > its functionality.
>> > my
>> > force approach.
>> > Luis.
Re: Unable to set background color of an SWT Button [message #454587 is a reply to message #454505] Mon, 25 April 2005 04:45 Go to previous messageGo to next message
But wait, this bug is a bug precisely in Windows!
As far as I know, the button background color DOES change in other OSs.
According to Chhil's reply:
"This is currently not possible on windows and there is bug report
filed"
And I have seen the bug report (id 23837), and it is reported as a Windows
bug.
Anyway, thank you for the info on the SendMessage call: I can always check
the OS before making the call, that way my code can still be portable.
"Emil Crumhorn" <crumhorn@speakeasy.net> wrote in message
news:d4e83m$9m4$1@news.eclipse.org...
me
info.
> Hope that helps,
> Emil
> > Hello,
> > change
> > but
code
> >> Hello Luis,
filed
> >> in bugzilla.
> >> -chhil
> >> Luis wrote:
> >> > Hello,
> >> > Shell
> >> > ignores me.
available
> > this?
> >> > change
> >> > on
> >> > its functionality.
> >> > my
> >> > force approach.
> >> > Luis.
Re: Unable to set background color of an SWT Button [message #454594 is a reply to message #454587] Mon, 25 April 2005 09:10 Go to previous messageGo to next message
Luis, please reopen 23837 with a link to the MSDN or a patch to fix the
problem on Windows but don't reopen the bug report unless there is enough
information to fix it. Thanks!
news:d4iarq$k7t$1@news.eclipse.org...
> filed"
> bug.
button
> me
> info.
> > Hope that helps,
> > Emil
> > > Hello,
> > > change
buttons
> > > but
> code
> > >> Hello Luis,
> filed
> > >> in bugzilla.
> > >> -chhil
> > >> Luis wrote:
> > >> > Hello,
> > >> > Shell
> > >> > ignores me.
> available
> > > this?
> > >> > change
depending
> > >> > on
> > >> > its functionality.
write
> > >> > my
> > >> > force approach.
> > >> > Luis.
Re: Unable to set background color of an SWT Button [message #454677 is a reply to message #454594] Wed, 27 April 2005 06:53 Go to previous messageGo to next message
I have been looking both MSDN and the source code of
org.eclipse.swt.widgets.Button and org.eclipse.swt.internal.win32.OS.
(Link to MDSN information about Windows Buttons:
http://msdn.microsoft.com/library/default.asp?url=/library/e n-us/shellcc/platform/commctls/buttons/buttontypesandstyles. asp)
Apparently some buttons in windows allow for a change in the background
color and some others don't. Specifically, only the ones of type
"BS_OWNERDRAW" allow for that. As the name implies, the application has to
draw the inside of the button, and that is what SWT does with arrow buttons
but not with the other ones.
So probably fixing the bug for arrow buttons would be relatively easy, while
providing the same functionality for the rest of the SWT button types would
require a bigger change in the code. Anyway that is not a crazy idea since
this is what .net does with all buttons.
In summary: I think there is enough information to fix the bug, but the fix
is not a simple one. Do you think that the provided information is enough?
Also, given the amount of work required for the fix, it may be a very
low-priority bug...
Luis.
"Steve Northover" <steve_northover@ca.ibm.com> wrote in message
news:d4iqcr$8l9$1@news.eclipse.org...
> > filed"
Windows
> > bug.
check
> button
surprise
> > me
you
> > info.
> > > Hope that helps,
> > > Emil
> > > > Hello,
to
> > > > change
> buttons
> > > > but
> > code
> > > >> Hello Luis,
> > filed
> > > >> in bugzilla.
> > > >> -chhil
> > > >> Luis wrote:
> > > >> > Hello,
SWT
> > > >> > Shell
just
> > > >> > ignores me.
> > available
for
> > > > this?
> > > >> > change
my
> depending
> > > >> > on
> > > >> > its functionality.
> write
> > > >> > my
brute
> > > >> > force approach.
> > > >> > Luis.
Re: Unable to set background color of an SWT Button [message #454679 is a reply to message #454677] Wed, 27 April 2005 09:23 Go to previous messageGo to next message
Please add this information to the bug report but don't reopen it. This is
the same conclusion that I came to a while back.
If fixing the button requires owner draw, then we aren't really interested
at this time. Owner draw has all kinds of bad problems associated with it
that don't seem worth it. Setting the background color of a control in this
day and age is dicy anways given the advent of themes and theme managers.
news:d4nr69$ghi$1@news.eclipse.org...
buttons
while
would
fix
> low-priority bug...
> Regards,
> Luis.
enough
OSs.
report
> > > filed"
> Windows
> > > bug.
> check
> > button
> surprise
> > > me
> you
the
more
> > > info.
> > > > Hope that helps,
> > > > Emil
> > > > > Hello,
> to
> > > > > change
Windows.
> > buttons
> > > > > but
that
> > > code
> > > > >> Hello Luis,
report
> > > filed
> > > > >> in bugzilla.
> > > > >> -chhil
> > > > >> Luis wrote:
> > > > >> > Hello,
> SWT
> > > > >> > Shell
> just
> > > > >> > ignores me.
> > > available
> for
> > > > > this?
could
> > > > >> > change
in
> my
> > depending
> > > > >> > on
> > > > >> > its functionality.
> > write
> > > > >> > my
> brute
> > > > >> > force approach.
> > > > >> > Luis.
Re: Unable to set background color of an SWT Button [message #454690 is a reply to message #454679] Wed, 27 April 2005 10:02 Go to previous message
Done!
news:d4o3v2$ssb$1@news.eclipse.org...
is
this
> > Hi,
to
> buttons
> while
> would
since
> fix
enough?
> > low-priority bug...
> > Regards,
> > Luis.
the
> enough
> OSs.
> report
> > > > filed"
> > Windows
> > > > bug.
> > check
portable.
> > > button
> > surprise
> > > > me
(or
> > you
> the
with.
> more
> > > > info.
> > > > > Hope that helps,
> > > > > Emil
> > > > > > Hello,
able
> > to
> > > > > > change
> Windows.
> > > buttons
> > > > > > but
> that
> > > > code
> > > > > >> Hello Luis,
> report
> > > > filed
> > > > > >> in bugzilla.
> > > > > >> -chhil
> > > > > >> Luis wrote:
> > > > > >> > Hello,
simple
> > SWT
> > > > > >> > Shell
the
> > just
> > > > > >> > ignores me.
> > > > available
prevails
> > for
> > > > > > this?
> could
> > > > > >> > change
> in
> > my
> > > depending
> > > > > >> > on
> > > > > >> > its functionality.
and
> > > write
> > > > > >> > my
> > brute
> > > > > >> > force approach.
> > > > > >> > Luis.
Previous Topic:tree layout
Next Topic:How to check System Clipboard
Current Time: Sun Jul 20 06:16:20 EDT 2025
Powered by FUDForum. Page generated in 0.06478 seconds
