Home » Eclipse Projects » Standard Widget Toolkit (SWT) » problem running as SWT APPlication.
problem running as SWT APPlication. [message #453953] Thu, 14 April 2005 14:44 Go to next message
Hello All,
Recently, I switched to using 3.1M6 from 3.1M5.
Earlier, I remember running SWT Applications using the rightclick option as
shown in the attached file.
I remember it working fine in 3.1 M5. But, when I switched to 3.1 M6, it
gives me the missing library error and the fix is forcing me to add the swt
library to java.lib.path. I never added it manually to 3.1.M5 eclipse. Is it
a new problem in 3.1M6.
This is the error I am getting.
java.lang.UnsatisfiedLinkError: no swt-win32-3128 in java.library.path
at java.lang.ClassLoader.loadLibrary(Unknown Source)
at java.lang.Runtime.loadLibrary0(Unknown Source)
at java.lang.System.loadLibrary(Unknown Source)
at org.eclipse.swt.internal.Library.loadLibrary(Library.java:12 3)
at org.eclipse.swt.internal.win32.OS.<clinit>(OS.java:18)
at org.eclipse.swt.widgets.Display.<clinit>(Display.java:125)
at Main.main(Main.java:17)
Exception in thread "main"
thanks,
Sridhar
  • Attachment: temp2.jpg
    (Size: 7.13KB, Downloaded 123 times)
Re: problem running as SWT APPlication. [message #453957 is a reply to message #453953] Thu, 14 April 2005 16:49 Go to previous messageGo to next message
Originally posted by: olivier_thomann.NOca.ibm.comSPAM
sck a écrit :
> Hello All,
From a previous message:
SWT Launcher will not work for M6 and may be temporarily removed - See
bug 88669 for details.
Olivier
Re: problem running as SWT APPlication. [message #453958 is a reply to message #453953] Thu, 14 April 2005 16:53 Go to previous messageGo to next message
Yes, this is a problem with the JARed plugins in Eclipse 3.1M6 build.
See bug 88669: https://bugs.eclipse.org/bugs/show_bug.cgi?id=88669
HTH,
Christian
Re: problem running as SWT APPlication. [message #453962 is a reply to message #453958] Thu, 14 April 2005 18:34 Go to previous message
We can wait ....it's a cool functionality to loose temporarily...;-).
"Christian Hauser" <christian.hauser@dvbern.ch> wrote in message
news:d3mlkr$n4j$1@news.eclipse.org...
as
swt
Is it
> HTH,
> Christian
Previous Topic:Drawing waveforms in SWT
Next Topic:Would be a SWING port of SWT sucessful?
Current Time: Sat Jul 19 19:13:38 EDT 2025
Powered by FUDForum. Page generated in 0.03106 seconds
