Home » Eclipse Projects » Rich Client Platform (RCP) » ProgressMonitor
ProgressMonitor [message #453620] Fri, 04 August 2006 05:58 Go to next message
I can open Progress Monitor with Job class in my Thread run. The problem is
that When press the Run Background button on ProgressMonitor dialog dialog
minimized but I cant maxisimized again. How can I it.
By the way Is the Job Class a thread. Becase I am using a thread and I am
calling Job class in run function of the Thread
Is there any disadvantage?
Re: ProgressMonitor [message #453636 is a reply to message #453620] Fri, 04 August 2006 10:29 Go to previous messageGo to next message
If you are running a Job, you do not need to (but certainly may) spawn an additional Thread (I am
pretty sure a Job either isA Thread or hasA Thread). I have half-a-dozen Job types running around my
RCP, and never once needed to say "Thread" in my code.
HTH,
Paul
Re: ProgressMonitor [message #453654 is a reply to message #453620] Mon, 07 August 2006 06:00 Go to previous message
For reopening the job, you have to integrate the progress-view.
1.
You have to define the view, in your own plugin.xml, because the view is
integrated in the org.eclipse.ui Plugin but will be defined by the
org.eclipse.ui.ide Plugin, that is probably not integrated in your RCP.
<view
name="%Views.Progress"
icon="icons/pview.gif"
category="org.eclipse.ui"
class="org.eclipse.ui.internal.progress.JobView"
id="org.eclipse.ui.views.ProgressView">
</view>
2.
activate the ProgressIndicator in your ApplicationWorkbenchWindowAdvisor
public void preWindowOpen() {
IWorkbenchWindowConfigurer configurer = getWindowConfigurer();
configurer.setShowProgressIndicator(true);
Cheerz,
Tom
Previous Topic:How to create a customized Problemview?
Next Topic:How to prevent other plugins from contributing actions to menubar
Current Time: Sun Jul 20 12:55:55 EDT 2025
Powered by FUDForum. Page generated in 0.03476 seconds
