Browser Widget on IE, scrollbar even if not needed [message #453462] |
Wed, 06 April 2005 07:26  |
If I use the Browser widget on Linux with Mozilla and get the
environment set up correctly, I am able to display markup
without scrollbars, etc. if I size the control large enough.
However, on Windows with IE I get a grayed out vertical scrollbar and
the whole thing is inset. I am using SWT.NONE as the style when I create
it. Anyone know how I get the stuff rendered flat without scrollbar on
Windows? I am doing this with Eclipse 3.0.1 and the browser is IE 6.
Thanks.
Chris
Re: Browser Widget on IE, scrollbar even if not needed [message #453798 is a reply to message #453534] |
Sat, 09 April 2005 15:20  |
Christophe Cornu wrote:
> You need to define the body tag as below.
> <body style='overflow:hidden;'>
> Full example:
> import org.eclipse.swt.*;
> import org.eclipse.swt.widgets.*;
> import org.eclipse.swt.layout.*;
> import org.eclipse.swt.browser.*;
> public class Main {
> public static void main(String[] args) {
> final String html = "<html><body
> style='overflow:hidden;'><h1>Some javadoc here</h1><p>and some more
> here</p></body></html>";
> Display display = new Display();
> Shell shell = new Shell(display);
> shell.setText("PRBrowser");
> shell.setLayout(new FillLayout());
> final Browser browser = new Browser(shell, SWT.NONE);
> browser.setText(html);
> shell.open();
> while (!shell.isDisposed()) {
> if (!display.readAndDispatch())
> display.sleep();
> Chris
Thanks. Actually, someone told me about the "overflow:auto" and I tried
that and it worked. I want it to have a scrollbar when it needs one and
not otherwise. That is what "overflow:auto" does. I still had the
inset box though. I had to use "border-style:none" to get rid of that.
Thanks again.
FUDForum. Page generated in 0.03118 seconds
