Home » Eclipse Projects » Standard Widget Toolkit (SWT) » eclipse 3.1M6: unable to run a SWT app
eclipse 3.1M6: unable to run a SWT app [message #453524] Thu, 07 April 2005 04:18 Go to next message
Originally posted by: sweinsto.ukonline.co.uk
I'm currently working on an application which use SWT.
I've tried to switch from eclipse 3.1M5 to eclipse 3.1M6. My project uses
the eclipse's libraries:
* org.eclipse.core.runtime_3.1.0.jar
* org.eclipse.jface_3.1.0.jar
* org.eclipse.swt_3.1.0.jar
* org.eclipse.ui.forms_3.1.0.jar
When I launch it through the context menu entry "Run as SWT application",
I get the following error:
Exception in thread "main" java.lang.UnsatisfiedLinkError: no swt-pi-gtk-3128 in java.library.path
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1517)
at java.lang.Runtime.loadLibrary0(Runtime.java:788)
at java.lang.System.loadLibrary(System.java:834)
at org.eclipse.swt.internal.Library.loadLibrary(Library.java:12 3)
at org.eclipse.swt.internal.gtk.OS.<clinit>(OS.java:19)
at org.eclipse.swt.internal.Converter.wcsToMbcs(Converter.java: 63)
at org.eclipse.swt.internal.Converter.wcsToMbcs(Converter.java: 54)
at org.eclipse.swt.widgets.Display.<clinit>(Display.java:122)
at com.mcafee.scmlov.App.main(App.java:57)
I have exactly the same problem when I run my application from the
command line.
In M5, there was an "external" shared library libswt-pi-gtk-3123.so but
in M6 this library has moved inside the swt jar.
Does someone know what is the right way for launching an SWT application
with M6.
Thanks in advance
Serge Weinstock
Re: eclipse 3.1M6: unable to run a SWT app [message #453525 is a reply to message #453524] Thu, 07 April 2005 04:45 Go to previous messageGo to next message
Same for me on any platform (WinXP, Mac OS X). I seem to have missed the
bug number, as this certainly has been reported.
I don't know, however, if this is due to the fact that I still use the
same workspace since 3.1M4.
Could anyone provide me with the related bug number, please?
Christian
Re: eclipse 3.1M6: unable to run a SWT app [message #453528 is a reply to message #453525] Thu, 07 April 2005 07:54 Go to previous messageGo to next message
SWT Launcher will not work for M6 and may be temporarily removed - See bug
88669 for details.
The following announcement was posted to the platform-releng-dev mailing
list::
SWT has moved to the new JAR'd format. The M6 format for Eclipse will be:
org.eclipse.swt._3.1.0.jar
plus one of ...
org.eclipse.swt.win32_3.1.0.jar
org.eclipse.swt.gtk_3.1.0.jar
org.eclipse.swt.gtk64_3.1.0.jar
org.eclipse.swt.motif_3.1.0.jar
org.eclipse.swt.carbon_3.1.0.jar
This will change for M7 to include the os and architecture (the final look
of this is still under discussion) :
plus one of ...
org.eclipse.swt.linux.gtk.x86_3.1.0.jar
org.eclipse.swt.linux.gtk.x86_64_3.1.0.jar
org.eclipse.swt.solaris.gtk.sparc_3.1.0.jar
org.eclipse.swt.linux.motif.x86_3.1.0.jar
etc ...
There will also be a new Standalone SWT Download format:
swt.jar
dlls / libraries
licensing files
This is simplified and will no longer include multiple jars like swt-pi.jar,
swt-mozilla.jar etc. The format of the SWT Standalone downloads might change
for M7. We are investigating a mechanism for including the libraries in the
jar but we have not yet decided if this is feasible or desirable.
NOTE: SWT Launcher will not work for M6 and may be temporarily removed - See
bug 88669 for details.
For more details, please see Bug 88122.
"Christian Hauser" <christian.hauser@dvbern.ch> wrote in message
news:d32s6t$ei6$1@news.eclipse.org...
> Christian
Re: eclipse 3.1M6: unable to run a SWT app [message #453532 is a reply to message #453524] Thu, 07 April 2005 08:24 Go to previous messageGo to next message
Originally posted by: aaa.domain.invalid
I removed the dll from the new jar and used the vmarg to specify the
library path to get this to work.
-Chhil
Serge Weinstock wrote:
> command line.
> with M6.
> Thanks in advance
> Serge Weinstock
Re: eclipse 3.1M6: unable to run a SWT app [message #453801 is a reply to message #453524] Sat, 09 April 2005 17:02 Go to previous messageGo to next message
If you run the application as a java app instead of a swt app all will
work fine. I had the same problem and Eric Clayberg at
Instantiations.com came up with this suggestion an it worked. By the
way www.instantiations.com makes a great GUI builder for SWT.
> command line.
> with M6.
> Thanks in advance
> Serge Weinstock
Re: eclipse 3.1M6: unable to run a SWT app [message #453805 is a reply to message #453801] Sat, 09 April 2005 19:18 Go to previous messageGo to next message
Originally posted by: bob.objfac.com
IIRC, Run as SWT app is broken in M6 because of the switch to the cool
new hey kid's let's put our entire plugin in a jar! fad. Good thing
there's a simple workaround.
Bob Foster
>> Hi,
>> * org.eclipse.core.runtime_3.1.0.jar * org.eclipse.jface_3.1.0.jar
>> command line.
>> with M6.
>> Thanks in advance
>> Serge Weinstock
Re: eclipse 3.1M6: unable to run a SWT app [message #453818 is a reply to message #453801] Mon, 11 April 2005 04:42 Go to previous messageGo to next message
I've tried that and I have still the same problem.
Even by extracting the shared libraries from the jar and by adding a
-Djava.library.path=XXX argument to the VM, I can't run my program from
Eclipse.
Serge
>> Hi,
>> command line.
>> with M6.
>> Thanks in advance
>> Serge Weinstock
Re: eclipse 3.1M6: unable to run a SWT app [message #453821 is a reply to message #453818] Mon, 11 April 2005 09:39 Go to previous messageGo to next message
Serge, did you place the three dll's in the winnt/system32 directory?
> Eclipse.
> Serge
>>>Hi,
>>>command line.
>>>with M6.
>>>Thanks in advance
>>>Serge Weinstock
Re: eclipse 3.1M6: unable to run a SWT app [message #453828 is a reply to message #453821] Mon, 11 April 2005 11:12 Go to previous messageGo to next message
No, I didn't as I'm currently developping on Linux.
The flag -Djava.library.path=path_to_my_swt_dlls_directory should avoid me
to have to put anything in the winnt/system32 directory.
In order to be sure I test my application on Windows and it works!
So the problem seems to be specific to linux/gtk2:
If I run from the command line: "java
-Djava.library.path=path_to_my_swt_dlls_directorypath_to_my_ swt_directory
-classpath=xxx myprogram.java", it works fine
But if I run it from eclipse with the option
-Djava.library.path=path_to_my_swt_dlls_directory, it doesn't work
>> Eclipse.
>> Serge
>>>>Hi,
>>>>command line.
>>>>with M6.
>>>>Thanks in advance
>>>>Serge Weinstock
Re: eclipse 3.1M6: unable to run a SWT app [message #453829 is a reply to message #453828] Mon, 11 April 2005 11:30 Go to previous messageGo to next message
Are you running it as a Java app and not a SWT App? The SWT app is broken.
>>>Eclipse.
>>>Serge
>>>>>Hi,
>>>>>command line.
>>>>>with M6.
>>>>>Thanks in advance
>>>>>Serge Weinstock
Re: eclipse 3.1M6: unable to run a SWT app [message #453830 is a reply to message #453829] Mon, 11 April 2005 11:59 Go to previous message
Thanks, I've created a brand-new launch entry with the right command
line arguments and it works now!
>>>>Eclipse.
>>>>Serge
>>>>>>Hi,
>>>>>>command line.
>>>>>>with M6.
>>>>>>Thanks in advance
>>>>>>Serge Weinstock
Previous Topic:Why do "PreferenceNode" trigger the exception ?
Next Topic:How to change button background color?
Current Time: Sat Jul 19 18:28:22 EDT 2025
Powered by FUDForum. Page generated in 0.06141 seconds
