Home » Eclipse Projects » Rich Client Platform (RCP) » More Path Issues
More Path Issues [message #453419] Sat, 29 July 2006 12:38 Go to next message
I earlier asked questions concerning reading a text file from an RCP and
received several helpful replies that did not work. However, I stopped
trying to put this text file in any specific location, added it to the
binary build, and postponed the problem.
When I execute the program as a product from inside Eclipse, but not
exporting it as a separate application, I can load the text file
successfully from the plugin start() routine.
When I export the application and try this, the file is not loaded.
I added another place in the application where I can try again to load the
file, from a menu driven action. This works.
My conclusion is that at the time the start() routine of the main bundle is
called, the paths don't yet exist, when I have an RCP that has been exported
cmpletely. But when running from inside the Eclipse environment, apparently
this path does exist.
Two questions: One, am I nuts? Two, if I have reconstructed this
correctly, when is the right point to make the file load? That is, when
does the bundle start() get called relative to other parts of the RCP
startup?
Thanks.
Re: More Path Issues [message #453420 is a reply to message #453419] Sat, 29 July 2006 15:35 Go to previous messageGo to next message
> startup?
> Thanks.
Hi Michael,
One, i don't know ;-)
Two, hard to say.
Please sent some code snippets next time.
If you store/load files within your plugin's scope (which is generally a good idea) then try this:
// Activatior.start()/stop():
ConfigurationScope configurationScope = new ConfigurationScope();
File directory= configurationScope.getLocation().toFile();
// do sth. with the directory
The ConfigurationScope works privately for the actual Plugin. Also usable within View/Editors or where ever you want.
The classes plugin membership will decide.
At last a hint:
You can open the "Debug..."/"Run..." Dialog (the little arrow right in the button).
There you can modify your start options like "Main/Clear workspace data before launching" and
"Configuration/Clear configuration area before launching"
sincerly
Dittmar
Quidquid latine dictum sit, altum sonatur.
- Whatever is said in Latin sounds profound.
Re: More Path Issues [message #453421 is a reply to message #453420] Sat, 29 July 2006 19:15 Go to previous message
Thanks. I moved the routine into the postStartup procedure and everything
works. But your code snippet may be helpful. Thank you again.
- Mike
On 7/29/06 1:35 PM, in article eagdad$1gq$1@utils.eclipse.org, "Dittmar
>> startup?
>> Thanks.
> Hi Michael,
> Two, hard to say.
> At last a hint:
> button).
> launching" and
> sincerly
> Dittmar
Previous Topic:language packs MacOS X 3.2
Next Topic:Activator - What is it?
Current Time: Sat Jul 19 16:35:59 EDT 2025
Powered by FUDForum. Page generated in 0.03982 seconds
