Using workspace in RCP Application - Part 2 [message #453345] |
Wed, 26 July 2006 21:19  |
Originally posted by: baldin.gmail.com
Hello again,
Stan, thanks if you help me again.
With teh last post, i got the Workspace root directory. But learning more
from IWorkspace, IWorkspaceRoot, i got this:
Workspace
-> Project
-> File
->Folder
->File
->Folder
But i want to save files and folder directly in WorkspaceRoot. I need to
respect hierarchy creating project and open before, or can do it ?
Geting the WorkspaceRoot.toString() path i can save and read file without
IResource interface, just using in the File name, but a think this is no
good idea......
I try this code, but i get Exception:
<<<<<<<<<<<<<<console exit
F:/runtime-EclipseApplication/servers.xml
servers.xml
error creating file
org.eclipse.core.internal.resources.ResourceException: Resource
/runtime-EclipseApplication does not exist.
at
org.eclipse.core.internal.resources.Resource.checkExists(Res ource.java:311)
at
org.eclipse.core.internal.resources.Resource.checkAccessible (Resource.java:187)
at
org.eclipse.core.internal.resources.Project.checkAccessible( Project.java:142)
the code
public static void createWorkspaceFile(String pathName, InputStream source)
try {
IWorkspace workspace = ResourcesPlugin.getWorkspace();
IWorkspaceRoot root = workspace.getRoot();
IFile file = root.getFile(root.getLocation().append(pathName));
System.out.println(root.getLocation().append(pathName).toPor tableString());
System.out.println(file.getName());
file.create(source, IResource.FORCE, null); //this raise
ResourceException
}catch (Exception e) {
System.out.println("error creatin file");
e.printStackTrace();
the use
LocalResources.createWorkspaceFile("servers.xml", new
ByteArrayInputStream("hello word".getBytes()));
Allot thanks,
Davi !
Re: Using workspace in RCP Application - Part 2 [message #453385 is a reply to message #453345] |
Thu, 27 July 2006 20:39  |
Originally posted by: zzhang.numericatech.com
Hi, David,
I am not sure if you can directly create files under Workspace root. I think
all the files must be under some project..
This might help you...
http://wiki.eclipse.org/index.php/FAQ_How_do_I_open_an_edito r_on_a_file_outside_the_workspace%3F
Sincerely,
Stan
"Davi Baldin" <baldin@gmail.com> wrote in message
news:ea94bn$ldk$1@utils.eclipse.org...
> Hello again,
> Workspace
> -> Project
> -> File
> ->Folder
> ->File
> ->Folder
> good idea......
> servers.xml
> error creating file
> at
> at
> at
> the code
> source) {
> try {
> ResourceException
> the use
> Allot thanks,
> Regards,
> Davi !
FUDForum. Page generated in 0.03067 seconds
