Home » Eclipse Projects » Standard Widget Toolkit (SWT) » asyncExec() func. doesn't work in parallel..??
asyncExec() func. doesn't work in parallel..?? [message #452967] Tue, 29 March 2005 06:25 Go to next message
I've written a code like below that.
Process #1 {
display.asynExec(Process #2)
I thinked that the order will be worked in parallel like this..
process #1 -> execution process #2
-> process #1 (at the same time)
-> process #2 (at the same time)
but the actual order is like this..
process #1 -> when the process #1 is ended -> process #2
"worked in parallel" doesn't mean that processes don't work simultaneously??
I don't know... ㅜㅜ
plz..... and thanks..
Re: asyncExec() func. doesn't work in parallel..?? [message #452972 is a reply to message #452967] Tue, 29 March 2005 07:16 Go to previous message
Originally posted by: Lamont_Gilbert.rigidsoftware.com
> Process #1 {
> I don't know... ㅜㅜ
If process #1 is not currently running in the UI thread, then there is
the possibility they will run at the same time. If process 1 is in the
UI thread, then no, it will finish first before process 2 is allowed to run.
CL
p.s. whether or not you see a thread switch is strongly tied to the
behavior of your OS which controls such things.
Previous Topic:set the combo box drop down list height ?
Next Topic:Why is the default DropEvent.feedback DND.FEEDBACK_SELECT?
Current Time: Sat Jul 19 11:56:57 EDT 2025
Powered by FUDForum. Page generated in 0.15081 seconds
