Home » Eclipse Projects » Standard Widget Toolkit (SWT) » difference between focusin and activation events
difference between focusin and activation events [message #452301] Thu, 17 March 2005 04:04 Go to next message
What is the purpose of the the activation event? When should I use this
event instead of the focusin event? (and deactivation instead of
focusout). I can't see any difference between both: each time there is
focusin event it seems there is an activation event (I have tested this
on a button control, using the mouse, the tab and alt-tab - on Windows).
I haven't been able to find documentation details about activation event
(even in the 2 books from Rob Warner and Steve Northover).
Francis
Re: difference between focusin and activation events [message #452310 is a reply to message #452301] Thu, 17 March 2005 07:38 Go to previous messageGo to next message
There are several differences
1) A parent (by parent I mean any parent in the parent hierarchy not just
the immediate parent) will receive an activation event the first time one of
its children gets focus. (As focus moves between children of the same parent
additional activation events are not sent).
2) It is not neccessary for focus to be assigned for the activation event to
occur - if a user clicks on the background of a Composite or Canvas or on a
widget such as a Label that does not take focus, an activation event will
still be sent.
"FL" <f.leboutte@algo.be> wrote in message
news:d1bh7b$qno$1@www.eclipse.org...
> Hello,
> focusin event it seems there is an activation event (I have tested this on
> Francis
Re: difference between focusin and activation events [message #452345 is a reply to message #452310] Thu, 17 March 2005 11:55 Go to previous messageGo to next message
Thank you, it helps a lot.
BTW, what is the best way to search into the archives of this group
where I should find a lot of hints (I'm new to SWT and Eclipse). It
seems that Google doesn't know this group.
FL
> still be sent.
>>Hello,
>>Thanks,
>>Francis
Re: difference between focusin and activation events [message #452348 is a reply to message #452345] Thu, 17 March 2005 12:34 Go to previous message
You can use the eclipse.org search page:
http://eclipse.org/search/search.cgi
The newsgroup is password protected so it doesn't show up in a Google
search.
Also there are many SWT code examples on our snippets page:
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/plat form-swt-home/dev.html#snippets
"Francis Leboutte" <f.leboutte@algo.be> wrote in message
news:d1ccq5$m1u$1@www.eclipse.org...
> Veronika Irvine a
Previous Topic:Larger image problems
Next Topic:Change Button Label on PrintDialog
Current Time: Sun Jul 20 18:37:27 EDT 2025
Powered by FUDForum. Page generated in 0.04823 seconds
