Home » Eclipse Projects » Standard Widget Toolkit (SWT) » TableColumn: setImage does not work correctly
TableColumn: setImage does not work correctly [message #451772] Tue, 08 March 2005 15:23 Go to next message
Hi there,
what's up with TableColumn.setImage??? I tried to set an image for a
TableColumn,
but it doesn't show an icon. Oddly enough, it does so when you embed the
setImage-Method within a SelectionListener.
This doesn't work -> Example:
final TableColumn column1 = new TableColumn(jobTable, SWT.CENTER);
column1.setWidth(50);
column1.setImage(imgSymbol);
This works: -> Example:
column1.addSelectionListener(new SelectionListener(){
public void widgetSelected(SelectionEvent e) {
Any suggestions ?
Re: TableColumn: setImage does not work correctly [message #451885 is a reply to message #451772] Thu, 10 March 2005 11:14 Go to previous messageGo to next message
Your example snippets look fine, so please log a bug report with Platform -
SWT and include the image that you're trying to set into the column header.
Grant
"Boris Munivrana" <bmunivrana@web.de> wrote in message
news:d0l1jc$vgd$1@www.eclipse.org...
> Hi there,
> TableColumn,
> Any suggestions ?
Re: TableColumn: setImage does not work correctly [message #451991 is a reply to message #451885] Sat, 12 March 2005 06:13 Go to previous message
thanks Grant, i'll do so.
> Grant
>> Hi there,
>> TableColumn,
>> Any suggestions ?
Previous Topic:SWT application that use DB
Next Topic:Screen Capture Win32 Window
Current Time: Sat Jul 19 14:16:36 EDT 2025
Powered by FUDForum. Page generated in 0.03389 seconds
